oh btw becareful of the air con vents
Amen to that. You can tell where Nissan saved pennies on the R32 dash :cheers:
Out of interest, does anyone know of a place that makes or can supply aftermarket R32 air vents? I was thinking of seeing if I can get some replacements made out of aluminium or similar: would make a vast improvement and last a lifetime IMHO.
Lucien
  • Replies 58
Lucien
you could get a metal fabricator do do it for you
but IMO it wouldnt be worth it
just get some brand new ones are they will last long enough
  • 1 month later...
I did the dash of my lancer and it came out very good so good in fact that people commented on that they did not know that it was a factory option... when painting plastic parts you must give everything a really good clean with a scrub/toothbrush then use a very fine sand paper to just rough up surface so that Plastic Primer will stick but before priming use some Prepsol to wash it down to remove any grease -wax dirt etc.. then several light coats of colour (acrylic) you can go to to an automotive paint supply place and they can custom make colours for you in an areosol can then after the paint has set then several light coats of clear after it has dried (24hr) use a mild cut and polish and apply to surface this will help to remove any minor dust and give the clear a high polished finish my interior parts lasted 3 years with no scratches or chips make sure you paint when it is warm and no dampness is in the air and place can of spray paint into bucket of hot water this will ensure when you spray the paint it will be thin coats and will not splatter onto surface
any tips on getting all the consol off successfully without doing any damage??
wanna give this a try but dont wanna fk anything at the same time, never pulled the consol/dash out before
anyone with a 33 that has done it please post steps??
thanks
well I had a try at pulling my interior apart on saturday and was surprised at how easy it all was and have finally decided on the colour looking at the PPG type paint that changes colour looking at red/blue/purple.... doing the gear boot and E brake in a blue micro sauede which will be followed through the rest of the interior and the seats will be grey and blue...
just need to work out how to remove the trim around the power window switch from the main part of the door handles and also the trim just under that were the door pockets are
any tips here :rofl:
  • 1 year later...
I'm with you man...Who needs air vents??
To paint the interior panels I did a very half-assed sanding, cleaned with a quick wipe of metho then painted with a coat of touch-up paint primer, then with a sliver metallic touch up paint, then with a clear coat again, from the touch-up-paint section! Over a year now and still shining.
  • 1 month later...
(Done on a 96 r33 series 2) CAMERA ISENT GREAT, so may be a bit blurry. but you get the idea of how it looks and how smooth it is
have done my dash and all interior. after trial and error, i found the only and best way to do this is:.. sand your plastic till all the paint is of and it feel smooth. (i used 240 to 400 grain sandpaper) then primer with gret plastic primer, (dont use clear primer!) i done about 3 coats, but to be real, just look at it and make sure the hole thing looks good, and the primer is all the same shade of grey all over the plastic. THEN..
paint, i help my bits in the air, so i could spin them with my hand to get it evan, and so there wasent light patches and everything was sprayed!.. again, i sprayed, held it for 1 min, then sprayed again, i kept going to it all was one color (shake can well to get it heated up, hotter the paint the thinner it is, so no spots or dark patches)
let it dry, then i sanded it with a 1200 grain sandpaper, very light motion with your hand, dont press hard, just hand weight on the paper, make sure you sand all of your bits, in sides, were the clock is, any little hard to get place, just rub your finger over each spot you have sanded and make sure its smooth, it should come out the same color you panited with but a little lighter, this is only to smooth out the paint.. now paint again till it looks good.. now that shoulds look smooth.. i sanded mine again, real light, then painted, the more you sand lightly, the smooth it will get... i painted, then sanded with 1200, thenm painted, then sanded, then painted . after this, do a cut and polish, i used a all in one, $8, rub it on, then rub off, then rub of with a clean cloth, now wet the part with water, and now clean with that clean cloth. make sure to get it real clean. now! that will make it shinnty ann super smooth. no one can do it beta..
i painted everything.. dash, side door, vents, window controls, door handle, the part above the speedo cluster, gota take everything out for that.. also painted the steering colum, looked crap without that painted. and painted key hole.. put my boost gauge in vent for the moment ..
i had a black sheet of plastic under the cd deck, just waiting to put some gagues or boost controller in there to make it look beta then the piece of crap tray i had there before, which looked out of place.. "
hope this helps any one. cause i fooled around a bit to get it perfect!..
(CHECK OUT WHAT THE ORIGINAL DASH LOOKED LIKE) i can never go back to that boring thing.. fells nicer to driver now and alot more modern from what people have been saying when they get in..
im still changing things to match. boot/handbrake / shift knob and seats.. wish i could use a silver momo wheel. but damn air bags!!
Edited by seriesII
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
