well this is for the people who dont want to fork out 1000 bux for a decent oil cooler! (see other group buy
full kit everything you need..
note that if you want to be a wanker buy a hks oil cooler for 1200, but if you want the job done buy this one!!! ( i have tested it and it does the job 80% of the the hks equivalant.... eg you are wasting your money on one that cost 5 times as much!!!!!!!)
cheap and easy to instal, everything you need is in the kit
pete
0409226626
https://www.sau.com.au/forums/topic/49705-remote-oil-cooler-kit-350-bux/
Might sound like a stupid question..
.. but can that fit where the old standard r32 intercooler goes if u had a fmic already?. It looks longer than normal?.. Would consider buying it only if some suggestions on where to mount it.
ceffo.
there are some mounting brackets
and its a big core
the kit comes with everything in the photo.. everything
apparently people are worried about about the efficiency of the core
note that the core isnt as good as a hks core. or as efficient.. however what it lacks in efficiency it makes up in shear size... (eg it large)
i get the kit from rocket at 335 wholesale including gst. so i make 15 bux on each one.. rocket is 40km away from my joint so it cost about 15 bux(round trip) in the r31 in petrol to get there
anyone who can get the kit cheaper wholsale speak up cause if we can get it cheaper then we will
pete
OK Pete, I'll take one. email me the details for payment [email protected]
I'm also going to fabricate a shroud to ensure clean flow over the core. You really are a legend mate.
BTW after seeing the Dutton footage I'm keen to know how much rubber you go through in a trip that long:D
Great price.
I want one but wondering where to install it as i have a pair of gtr bov's where the stock IC goes and the cooler piping off the fmic might block the vent to much on the drivers side to install it there!!!!
ANy suggestions geoff :P PS wanna help me install it if i get one :(
im installing my flat informt o fthe engine btw the radiator and the ic
however just informt of the ic condensor is the go me thinks for people with space constraints
look like thats the only place i can install it is around there, but then come down to blocking airflow to the radiator
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
