  • Replies 56
200 3rd gear passenger in a r33 gtr at 6400rpm .. had to tell him to back down coz the speed wobbles on the rims was pretty hairy.
Was it an auto ?? he he - Cause 3rd gear in a manual won't be that fast.
I've redlined my line in 4th and taken it to about 6k in 5th down the main straight at EC - but f'd if I know what speed I was doing - cause I was looking at the good damned road ahead - and that f'ing nasty hight speed corner at turn 1.........
I did this on a Dyno so nothing illegal here, 261KPH on the RSM and 260KPH is what the dyno machine read. Hit rev limiter at 7200rpm. Was pretty impressed with the accuracy of the RSM actually. But then again is doesnt take into account wind resistance, tire friction and of course the good old VIC police.
ya, take into account the resistance of the air @ 260 and its a lot different.
For ALL you guys mentioning roads etc
Edit/remove your posts. SAU doesnt condone high-speed street activities
If you dont, i'll do it for you, and you may well cop a warning
Good to see lots of people are doing it on the track though. Much safer :D
My line - dunno. Had it up to 190ish (limiter) plenty of times, but haven't had it out at the track since PFC went in due to dying/dead coils, which I'm currently too pov to fix.
Bike - somewhere around 250-260 at Darlington Park, maybe could have gone a few km/h quicker but was already crapping myself about the blind right-hander at the end of the straight! I've seen 288 on it, at an airfield way out near where I was contracted at the time. Wanted 300 but not enough tarmac.
Warnings have been handed out.
again, i'll say...
SAU Does not condone illegal street behaviour.
Simply dont post up about it if you didnt do it on a track
if people cant follow that, thread will be closed.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
