  • Replies 59
yeah i guess it'll do for now...
yesterday I was driving to Glenny and along Springvale Rd just on the intersection with Burwood Hwy next to the Fridge (liqor outlet) is this HUUUUUUUUUUUUGE carpark and a hotel/pub as well. it'd be awesome to use as a meet spot.
I'm member number 006... just like 007 but I came first.
hi everyone!
i had a good time and i finally managed to get some faces to aliases/avatars... kinda strange actually! It was really cool to see so many nice 'lines around!
Keep up the good work!
oh and here are some shots that me and my bro took!
- he's not a member :D
photo 1: HERE
photo 2: HERE
photo 3: HERE
Kor
thats the burvale hotel.
used often, but very much east, too far for west members.
The Whitehorse is far more central in general terms
what that nong said... the whitehorse is perfect.
plus i bet they dont have 13 snhitz at the burvale!
(altho if they have coopers on tap i may consider swaying my vote :D)
lovin the Camaraderie, dont even have my car but SOOOO cant wait to come stuff around with all you guys and girls. btw im a boy and i like to cook :D (this is in no way a volunteer to cook :D)
cant wait early october!!!!
WE HAVE AN OFFICIAL SAU CHEF!!!
good work...
ok ash ur relieved of ur duties :D
Hey guys - fantastic turnout. Really good to see that so many people are supporting the club. A lot of stuff has gone on to get this organised and I can tell you that we really appreciate the response.
The club will only grow from here but it's strength and enjoyment will be more dependent on its members than those of us on the committee. And for me the most pleasing aspect of yesterdays club launch was the social interation between you guys. It was really good to see and it's something those of us on the committee hope to promote as a big part of this club.
Also good to see many guys interested in the CAMS side of things. If anyone wants anything further answered feel free to contact me.
Cheers guys.
:D
Good work Vic.
A great turnout with great people. Ash, good work with the snags mate. I don't care how they looked, it's whats on the inside which matters :D
008??? Does that mean I'm one better than 007 or am I just gonna be lucky??
See you all at MAS!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
