Might be of interest to the track teams....
Group buys on sabelt harnesses?? 4 Points and expire in 2009.
They also come with with the shoulder pads.
Theyre selling for just over $200AUD without shipping or taxes so probably cost less than 300 to get them landed.
How much are they usually???
http://nifty.amikai.com/AmiWeb?ami_url=htt...393819&r_n=4436
EDIT: ok it wont work so i will have to do it the pov way with screen dumps haha.
Pretty much the jist of it is that on yahoo japan they are selling them for 17400yen... that is the selling price not th start price. That works out to be just over 200AUD... shipping those things wont be a hell of a lot from Japan either so postage will probably be around $40 (PFC costs $40 and id say that weighs more)
  • Replies 50
Theyre 3"
レースなどでの使用期限は2009迄です
The use term in a race etc. is to 2009.
★ここに注目!
* Observe here! 送料+しても、国内最安値!
Even if it mailing-cost + Carries out, it is a domestic maximum low price!
★品名
* Name of article サベルトTOP-FOMULABオール3インチパッド付 右用 青
With a SABERUTO TOP-FOMULAB all 3 inch pad For the rights Blue
★特徴
* Feature 2004年モデル正規輸入品。4ドア車からMR2などの2シータ-まで調整幅が大きい為取付けが容易。FIA公認で公式戦にも使用できます。
2004 model regular import. Since even 2 Sita, such as MR2, has large adjustment width from 4 door vehicles, attachment is easy. It can be used also for a regular-season game by FIA official recognition.
★国内参考価格
* Domestic reference price 22000円位
22000 yen grade
★bakebake販売価格
* bakebake selling price 17400円
17400 yen
★オプション販売1
* Option sale 1 サポートベルトV型(6点式)    4000円
Support belt V type (six-point formula) 4000 yen
★オプション販売2
* Option sale 2 サポートベルトI型(5点式)    3500円
Support belt I type (five-point formula) 3500 yen
★オプション販売3
* Option sale 3 ベルトキャッチステー(取付けが容易になります)    1050円
Belt catch SUTE (attachment becomes easy) 1050 yen
★オプション購入について
* Option purchase 購入ご希望の方は落札後、ご連絡下さい。
Those who wish [ purchase ] need to inform after a successful bid.
★振込総支払額
* The transfer total payment frame 17400円   +  送料
17400 yen + Mailing cost
★代引(525円)総支払額
* The cost 引 (525 yen) total payment frame 17925円   +  送料
17925 yen + Mailing cost
送料
Mailing cost
中部、北陸、近畿
The central part, Hokuriku, Kinki  900円
900 yen
関東、信越、   中国、四国
Kanto, Shin-etsu China, Shikoku 1000円
1000 yen
東北、九州
A northeast, Kyushu 1100円
1100 yen
北海道、沖縄
Hokkaido, Okinawa 1400円
1400 yen
送料・支払について
About a mailing cost and payment
♪支払総額
Total ♪ payment amount 落札金額+送料
Successful bid amount-of-money + mailing cost
♪その他
♪, others ノークレーム・ノーリターンにてお願いします。
I need your help by the no claim no return.
リンク
Link
♪マイブース。私の現在出品している他の商品は こちらをご覧ください。
♪ my booth. Other goods which have sent now [ of me ] Here Please have a look.
My Sparco harnesses are actually Sabelt. Mine look the biz so these are great value, most this price dont have the quick release buckle...lol you feel quick just doing up the buckle:)
Just be sure they are the long type, as some are "short" type for mounting of roll cage, most of us need the "long" type to mount off the rear parcel shelf
I got my sparco bonnet pins from Meridian Motorsport.... cost $35 but I think the price is a bit higher now.
As for the Sabelt TRW harnesses... If they're the blue one's pictured above with the 3" straps, rotor buckle (jet fighter style) and long straps for parcel shelf mounting then im in!! :D
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
