  • Replies 148
Posted Images
  • 1 month later...
just wondering do u cover the hole lot? or just the steam of it?
I have read the previous replys and and not sure where exactly you are putting the epoxy glue on the pack.
If you look at my 4th post, I have posted pictures of where to put it.... doesn't get any easier
You guys are confused about the whole silicon thing.
What you want to do is spray the coils liberally with silicon spray
It's an aerosol lubricant, looks & feels like oil, repels moisture superbly - not a curing sealant.
I had an arcing coil issue some time back, now whenever I change the plugs I spray the coils liberally and hey presto no more probs. If you're hellbent on a more permanent fix, why not tape them up with (are u ready for this) self amalgamating butyl tape. Goes on like leccy tape, then heat with your paint stripping gun etc, et voila fuses together and shrinks around the coil insulating and waterproofing it.
When I was contracting for Sydney Water we used this stuff on external electrical connectors on sensitive datalogging equipment that was mounted inside sewers - not an electronics friendly environment. High temps, lethal caustic gases and flooding are the norm.
Should be able to get this stuff from Electrical wholesalers, Blackwoods etc.
M'kay ??
Yeah, but I would be inclined to coat the inside with the goo that Telstra use for cable jointing to repel moisture. I don't know it's proper name - but it's clear & has the texture of grease. I reckon leccy wholesalers would have it.
Just thought I would update this thread with some more info....
Although my coils were covered in araldyte, they started playing up again on the weekend, so I pulled them out including spark plugs to see what was going on....
Well first of all, my tuner gapped my spark plugs like so:
1:0.6mm, 2:0.7mm, 3:0.7mm 4:0.75mm, 5:0.6mm, 6:0.6mm
not to mention a whole bunch of bolts missing all over the place, but anyhow, once they were re-gapped I turned to the coils.
Upon inspection the araldyte looked fine. No cracks, no chips.
So I took the rubber boots off, and the little springs inside the shaft and notice the shafts were a little corroded (that blue/green crap you get on your battery terminals). So I sprayed the shafts with WD40, and cleaned them out with steel wool. The car runs better than it ever has now, and is very smooth.
So also take this into consideration when looking at your coils.
Z
You've raised a good point, Zahos.
moisture seems to play more in the faulty coil/misfire scenario than many of us had previously thought. I revived one dead coil and brought two DOA's back to life with silicon spray, and noticed the same corrosion @ the spring terminal. I still reckon heaps of gooduns get tossed, where the real culprit is condensation.
My 2 zloty
  • 3 months later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
