  • Replies 148
Posted Images
  • 1 month later...
just wondering do u cover the hole lot? or just the steam of it?
I have read the previous replys and and not sure where exactly you are putting the epoxy glue on the pack.
If you look at my 4th post, I have posted pictures of where to put it.... doesn't get any easier
You guys are confused about the whole silicon thing.
What you want to do is spray the coils liberally with silicon spray
It's an aerosol lubricant, looks & feels like oil, repels moisture superbly - not a curing sealant.
I had an arcing coil issue some time back, now whenever I change the plugs I spray the coils liberally and hey presto no more probs. If you're hellbent on a more permanent fix, why not tape them up with (are u ready for this) self amalgamating butyl tape. Goes on like leccy tape, then heat with your paint stripping gun etc, et voila fuses together and shrinks around the coil insulating and waterproofing it.
When I was contracting for Sydney Water we used this stuff on external electrical connectors on sensitive datalogging equipment that was mounted inside sewers - not an electronics friendly environment. High temps, lethal caustic gases and flooding are the norm.
Should be able to get this stuff from Electrical wholesalers, Blackwoods etc.
M'kay ??
Yeah, but I would be inclined to coat the inside with the goo that Telstra use for cable jointing to repel moisture. I don't know it's proper name - but it's clear & has the texture of grease. I reckon leccy wholesalers would have it.
Just thought I would update this thread with some more info....
Although my coils were covered in araldyte, they started playing up again on the weekend, so I pulled them out including spark plugs to see what was going on....
Well first of all, my tuner gapped my spark plugs like so:
1:0.6mm, 2:0.7mm, 3:0.7mm 4:0.75mm, 5:0.6mm, 6:0.6mm
not to mention a whole bunch of bolts missing all over the place, but anyhow, once they were re-gapped I turned to the coils.
Upon inspection the araldyte looked fine. No cracks, no chips.
So I took the rubber boots off, and the little springs inside the shaft and notice the shafts were a little corroded (that blue/green crap you get on your battery terminals). So I sprayed the shafts with WD40, and cleaned them out with steel wool. The car runs better than it ever has now, and is very smooth.
So also take this into consideration when looking at your coils.
Z
You've raised a good point, Zahos.
moisture seems to play more in the faulty coil/misfire scenario than many of us had previously thought. I revived one dead coil and brought two DOA's back to life with silicon spray, and noticed the same corrosion @ the spring terminal. I still reckon heaps of gooduns get tossed, where the real culprit is condensation.
My 2 zloty
  • 3 months later...
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
