I just bought my car and found out with alot of research that i have this turbo in my r32 gtst skyline. my only mods when i bought the car there was a fuel regulator, 3 inch exhaust and dump pipe and and pod filter...its boosted to 15psi at the moment. Just wondering what power gains should i be reaching with this sort of turbo. Is it rated better than the HKS GT2530? i was thinking it is as its bigger. but the 2530 is smaller so it will have better low and mid range response?
https://www.sau.com.au/forums/topic/51282-hks-gt2835-turbo-help/
power gains arent great unless u have the back up items to match. Sure its a bonus that u have this "Larger" turbo but without a front mount cooler i wouldbe winding boost down to 12-13psi, i made that mistake and im rebuilding my engine, do urself a favour, before going insearch of power, go insearch of back up systems to suit(ie computer, fuel pump etc)
Is this a better turbo than the hks GT2530? coz yeah i dont have a front mount , but i have a remapped ecu, im pretty sure i dont have a bigger fuel pump...do u guys think this is the reason why my car seems even slower and has alot of lag? coz i dont have the power system to back up this turbo?
If your car does indeed have this turbo, I suggest following the recommendations of people already and fitting a front mount asap. You should also be addressing your fuel supply issues and fitting a higher flowing fuel pump and looking at some larger injectors.
If you get these areas sorted, you should end up with a fairly tidy package
Take your car to a reputable workshop and have it checked. If I was you I wouldnt be so focused on how much power this turbo of yours might make.
I'd be confirming once and for all what you are running and checking that everything is in good order before you run into trouble.
Aybee he would get much more than that in my oppinion. The 2835 is larger and flows mopre than the 2530 and 2530 can get 200rwkw easily... My mate has his 2530 making 210rwkw @ 17psi. Should make around 230 or so?? How do these go on a RB25?
what?
so are you saying that it should make much more than 250rwkw? or around 230. cause i said that it would be good for "mid 200's" meaning around 240-260rwkw.
But thats whay ive always thought my car would be good for and its slightly more powerful than the std 2835 (420ps compared to 380ps)
Ok i have been waiting for a 2535 for a month now... not sure whats going on but aparently HKS have them on back order and cant give a definate eta. Does anyone know how the 2835 will stack up compared to the 2535? i may go bigger... is it laggy? will i need cams? ANYONE PLEASE! ps its for a RB25DET
HKS GT2535 - 340 PS Output
COMPRESSOR:
-Wheel- 56 Trim - 51.6 Inducer / 69.0 Major
-Housing- 60 Inlet / 50 Outlet - 0.60 A/R
TURBINE:
-Wheel- 76 Trim - 53.8 Major / 47.0 Exducer
-Housing- GT25/T3 inlets / Outlet specs:
Internal GT25 outlet; 0.64, 0.86 A/R
Skyline Type; 0.64 A/R
HKS GT2835 Pro S - 420 PS Output
COMPRESSOR:
-Wheel- 56 Trim - 53.1 Inducer / 71.1 Major
-Housing- 100 Inlet / 50 Outlet - 0.50 A/R
TURBINE:
-Wheel- 84 Trim - 56.5 Major / 51.8 Exducer
-Housing- T3 inlet / Outlet spec:
Internal GT-Pro; 0.68, 0.87 A/R
I'm going out on a limb here - but my guess would be that the 2835 will be laggier. (80PS Difference)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
