"sorry about the shaky camera" i don't blame you :)
i was about 100m away and i jumped...
I was drunk, and I haven't slept since Friday night...
aww hell, I still am drunk, and I still havent slept, but yea, I wasn't really paying attention until that happened =
  • Replies 96
yeah it was nasty as to see it. it had just started to take off when i saw a huge thing of flames and heard the loud bang...i was standing right at the front of the gates where they switch the cars ova and also heard him/or someone else...? ask the guy if he wanted him to take the NOS tank out of the car. the guy in the orange top held up the piece of piping that had burst and the end looked like they and been blown apart
I bet the nos has backfired.
If you watch the video you can hear they slow it up and then give it the boot and if the nos was engaged when they did that then it would have filled the plenum and cylinders with gas.
Nitrous is a very funny thing and if you stuff up with it it can go very bad very quickly.
I will let Leewah explain exactly what happened, but
YES, it was a nos related incident
NO there was no engine damage
NO, no rods, pistons, or engine related parts were affected
Yes there is one less greddy intercooler pipe in the country :)
How do i know this, well i drove it afterwards....in NA mode :)
Please dont post things that you dont know as fact.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
