Hey ppls.
Well, I'm now starting my next project after the Radiator guides.
I'm going to be making up a bunch of aluminium pipes from the Air Flow Meter to the mouth of the turbo.
Reason?
It is well documented that at boost levels of around 0.9 bar, the standard rubber pipe can suck closed, resulting in everything you would expect to happen with bugger all air getting into the engine.
Also, in hot weather this phenomenon will happen easier as the pipe heats up and becomes softer.
Solution?
I'm making up a section of pipe that will 'splice' into the standard AFM to Turbo duct. You will simply cut the standard Rubber Duct and remove a small section of rib, then insert the section of pipe, then clamp up the pipe and reinstall the new duct.
Construction?
Mandrel bent pieces aluminium, in a raw finsih, TIG welded. No polishing will be done, but if you want to do it when you recieve your pipe, the aluminum is ready for it. There will be sufficient pipe at either end to give a good seal to to the air. The best finish will probably be either anodised or powder coated. I would recommend podwer coating personally.
Currently the R32 and R33 rubber ducts are down at the fabricators being prototyped, and I expect a sample of each back early next week (24th - 26th January 2005)
Not sure of the final price until I get the samples back.
The standard duct will not be able to be returned to standard after fitting the new section of pipe, but the duct will be such that it will be virtually invisible to the untrained eye.
They will fit in a TNT Airbag, so freight anywhere in the country will be $15.
Maybe if somebody in each state wants to be a distributor the freight can be greatly reduced.
So, who's interested??
Please advise your model of car.
R31s
Angry (RB20DET)
AnFz
Total R31 = 2
R32s
-Joel-
Sheepy
Predator
WazR32GTS-T
KICKIN (Ceffy)
FAT32
Jolinator
TurboX
26GTS
tkch55
sskylinee
Memph
Total R32 = 12
R33s
RedlineGTR
Robo's
Pinoi-Boi-r33
Riceline
B1 Mr_Fanny
Wolverine
Xr8Eater
gtrGhosTDoGG11
burnfest
SydnetKid (Stagea R33)
Jay95R33 (Stagea R33)
ICE12 (Stagea R33)
SKYBEE
|PRESA|
Trust33
tridentt150v
BLakniTE
SKYNUTS
lbfalcon
GOR33
Bobjones
CMS Drifter
knore
drewecrome
halz
R33 newbie
predator
R33_KRAZY
nacional
craz0
gts-wpn
LANFOH
Babia
r0ma
NZM.031
Zebbie
MYSTR33
Total R33 = 37
R34s
ME of course
Adzmax
Daz
Muz
Abo Bob
Coxy_
GTTR34
Neo_R34
CNBLOW
HKS34R
ascension
Total R34 = 11
Total So Far 62
BASS OUT
https://www.sau.com.au/forums/topic/51709-group-buy-afm-to-turbo-duct/
  • Replies 309
Very interested but I can't say for sure until I have a closer look at my intake and see how exactly my pod has been fitted.
But after the last group buy I can highly recommend Bass's work. Great quality air guide and lotsa communication as to progress etc.
Hey guys.
Regarding the location of POD filters and the like, I think with a simply modification to the filter bracket, any misalignment issues would be sorted out.
When I fitted my Pod filter (fully boxed off Mr. Plod) the location of the AFM was very very similar to the standard location.
Obviously when I make up the AFM pipes, I will put my standard Airbox back on to make sure everything is spot on.
Different AFM sizes??? Internaly they are the same.
Different Colour Silicone.... I might well be working with Shift Performance or somebody like that for them, so you will be able to request different colours. I'm making mine black with black pipes.
Also, I may be able to powder coat or anodise the pipes if you want to match engine bays, but obviously these things will cost extra and it's something I can only do if a few people want to do it (anodising that is). Powder coating will be easy.
BASS OUT
Guest
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
