just had an SAFC installed and tuned on my R32, made 271.6hp
my question is... what next? are there any bolt ons available to give me more power or have i reached the end of the road?
so far;
t04e turbo
front mount
bosch 910 fuel pump
all the other crap like exhaust, filter
blitz ECU + SAFC
thanks everyone!
adam
https://www.sau.com.au/forums/topic/5221-270rwhp-now-what/
Thats excellent news :D
Adjustable cam gears are a bolt on mod. You'll find maybe 15 - 20 hp from tuning cam timing. Nengun has light weight HKS ones for ~$185 each. RB20 can use 2, one for intake and one for exhaust cams. It'll need tuning on the dyno to setup but the s-afc won't need to be retuned.
If you're on a budget, the exhaust adj cam gear alone would provide most of the power increase (probably 3/4 worth).
For R33 RB25 ppl, only the exhaust adj cam gear can be installed cause inlet cam gear is integrated with VCT.
https://www.sau.com.au/forums/topic/5221-270rwhp-now-what/#findComment-80179
yeh i think ill go down this wednesday (30th) if not then in the near future. with 110rwhp more i think i can better the 14.6 of last time :burnout:
yeh adjustable cam gears i think will be the next.
anyone one which injectors will fit the std fuel rail?
im currently running a bleeder, would an EBC be worthwhile for holding boost above 1bar? (im running a HKS external gate)
https://www.sau.com.au/forums/topic/5221-270rwhp-now-what/#findComment-80221
wikid!
somehow I reckon you'll deinately be getting a better time than 14.6 hahaha :uh-huh:
what clutch do you have? that'd be a good thing to change, or else timing/cams/nos(:))
and if you're restricted by your management system, why don't you upgrade that?
:D
make sure you're there this wed!! I want some good videos :burnout:
https://www.sau.com.au/forums/topic/5221-270rwhp-now-what/#findComment-80232
tuning and fitting cost $150, the SAFC cost $150 (the older series one)
power went from 226 to 271 so 45rwhp. off boost its no different raly, the fuel curve is fine but on boost its been leaned out a little so goes alot harder there.
the problem is ive got a blitz ECU, HKS PFC which cannot be unplugged because no-one nows the wiring and its running off a MAP sensor which may screw things up. on top of that ive got an SAFC, so 3 computers:P
https://www.sau.com.au/forums/topic/5221-270rwhp-now-what/#findComment-80235
Guest nismogtsx
Where di ya get ya hand on the older SAFC....
I just bought a brand new one and a mate of mine what one...
Maby i can sell him the new one i bought and get an older one...
As the features that the new one has over the old one cant be used on my car as it is fairly old too. The only difference is the screen i recon.....
Call me if ya get get one for me PLZ 0417127768 (Colin)
https://www.sau.com.au/forums/topic/5221-270rwhp-now-what/#findComment-80332
i got cypher to do it
they charged 1 hours dyno time ($110) for fitting, tuning and power run
which i thought was pretty damn good! and despite what some say, i rate cyphers work very highly!
yeh i got ya pms ive just been too lazy to reply! :D  ill do it now...
Would it cost the same to tune the blue screen model SAFC as the one you've got do you think?
https://www.sau.com.au/forums/topic/5221-270rwhp-now-what/#findComment-80578
OK so for my R33 you would advise not to get a new cam gear for the inlet. So does this mean i should just by one cam gear for the exhaust? so at $185 each then how much for installation and tuning? this could be one of the cheapest and best mods yet if it gives 15 - 20 rwhp...
is there any set backs with light weight cam gears... pros and cons??
https://www.sau.com.au/forums/topic/5221-270rwhp-now-what/#findComment-80867
Hey adam who exactly at cypher did the tune job? or have they got a dyno now?
https://www.sau.com.au/forums/topic/5221-270rwhp-now-what/#findComment-80888
Yeah, 1 cam gear for exhaust. It may be possible to modify the orginal intake gear to make it adjustable but I haven't heard of anyone doing this first hand. I couldn't see install and tuning taking more than an hour on the dyno.
Don't quote me on the HP gain. Basically, go in expecting drivability gains (lower spool up time) and be happy for any HP increase. Your milage may vary :-) Not aware of any cons, pro of lightweight gear is less reciprocating mass on the head -> less engery lost in turning cams.
https://www.sau.com.au/forums/topic/5221-270rwhp-now-what/#findComment-80902
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
