Hey Guys,
In prep. for the track day at Sandown next month I'm getting the brake fluid changed to a track ready spec so I don't boil it after a couple of laps :flamer:
For those of you (read: any Team Wang members :) )who have changed their brake fluid to a track ready type (higher boiling point) which readily available brake fluid would you recommend for a r33 gtst?? Just to note that the setup is std except for upgraded pads.
Also are there any compromises to using this fluid on the streets?
Thanks
ant95gtr.
https://www.sau.com.au/forums/topic/52320-which-brake-fluid-to-use/
  • Replies 40
I use the Castrol SRF. Its (apparently) the best - but will send you broke.
Most of the guys use the Motul Dot 5.1. The only adverse effect I know about high quality brake fluids is the lightening of the wallet effect. I stand to be corrected on this however.
Thanks for all the info guys.....had my car at calder a couple of weekends ago at a driver training session.....the comp. circuit isn't very long or hard on brakes but by the end of the day I had to stick my foot through the pedal in order to wash off any speed. Not the best feeling when hoofing ur car round a track ;) I figure that sandown is waaay harder on brakes so gotta get that fluid changed!
Yeh brake fluid is important, and i have no doubt that the Castrol stuff it top shelf, but i suspect most of use can make do with less.
I posted this before...
... i use AP Racing Formula DOT 5.1 Road/Competition Brake & Clutch Fluid. Part No. CP4510 , but may change to Motul RBF 600 whish i have heard good things about. Cheaper and still very effective is the Caltex GP 600 Racing Brake Fluid.
There are lots of guys running the Caltex up in Sydney as Race Brakes up there are now readily using it in all the street / track cars as they have been getting good results with it and it almost a third of the price of the AP stuff i use....from memory it cost $30 for 600ml .
Disregard above post....i need new fluid and pads before Sandown as well so just got some prices together.
The two parties i spoke to said dont bother with anyting other then Motul RBF600, which is $25 for 500ml. They are using in Stokell's Diablo and its working better then all the previous fluids. So good enough for me.
Also as far as pads go, (Prices are all form Race Brakes - Melb)
DS3000 are $385
Track only...save your road pads for the road and race pads for the track. They are actually easier on rotors with less grinsing when they are aup to temperature...so noise isnt the only reason not to use them on the street
DS2500 are $231
Road/track but as Snowman will tell you they aint exactly a great road pad.
RB74 are $160
What i have been using and have always been very happy with, Race Brakes still seem to think they will be up the job at Sandown given my cars weight power and tyres.
As my RB74s have about another 6-9 months of normal driving in them, im leaning towards the DS3000s (or the SAUWA - Hawks) for the track, since ill be changing wheels its only an extra 5 min per corner.
I am going to tack onto this thread and add...
Just got back from picking the car up from Meridian, top stuff in spending like 7 hours fitting the oil cooler to my beast!
I was initially going to get a set of Endless CC-R ceramic pads, but brent from nengun can't seem to source / get the parts... so... time is running out and I need to sort out my brakes.
Was talking to Toby at Meridian, and he was considering organising a group buy on braided lines (though prob not before Sandown).
Also, he uses an ATE brake fluid, one litre for like 50 bucks.
As for pads... thinking the RB74s might get a guernsey as a stop gap before I get these Endless pads. Does anyone think it is worth doing the DS2500s?
I have just fitted a set of ADR approved braided brake and clutch lines. I purchased these for $420 (brakes: front and rear) and $70 (clutch). The brakes are a two piece hose with a block in the middle, just like the originals, and bolt up in the original fittings. I have not yet felt the brakes as the car is still at the w/shop.
MALTECH: Brake Hoses & Cables
0418 378 939
(03) 5253 1931
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
