Hi there. Well, I went for a cruise today in Keir Wilson's 9 second
R32 GTR. Very impressive car - smooth, tractable, & awesome acceleration.What impressed me the most was how street driveable it really is.It idles well, can take off in 3rd gear, & putts through the gears at fairly low revs without a problem.It still has Air conditioning, power steering,2 seats & being an Australian delivered car, it is in impeccable condition.
Keir truly deserves the title of having the first Australian RH9 GTR.
Well done to him & his Willall racing team - great effort.
Cheers,
Munro.:D
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/
Yes, a congratulations must go to Keir and his team, however records were made to be broken. Im sure you are not far off Munro, and there are a couple of potential cars in vic that are being built. Will make for an exciting summer. When is the next major meet?
Im going to heathcote on the 16th of november (unfortunately not to compete....yet:)) to see a meet.
I may stir up a few emotions, but is having a 3ltr GTR cheating?
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80314
what is an RH9? i'm guessing it has something to do with being in the 9 second bracket for 1/4 mile?? different engine.
i keep seeing it pop up every now and then, but never know what a RH9 Skyline is??
:confused:
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80343
basically means a road registered 9 sec car... ie. u drive it there do ur run... oh look 9 seconds... drive it back home again :D
more or less... do a search in this or the wasteland on RH9 cause there is a post that someone made about the fastest GTR in australia in which there is a large explination into what it really means.
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80374
Why would 3ltr's be cheating? It's just another way to go about making power...
I know that there's a few Jap RH9 cars running around with the OS 3ltr conversion!
Go the 3ltrs! :D
matt
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80407
I also know of a certain red 33 with a 3ltr:D I didnt really explain myself properly, while I would shudder at the expense and effort that goes into a 3ltr, and respect to all those people who have done it, there was a reason that nissan didnt build the 3ltr for the GTR, and that was to allow it to rev harder. Its the age old compromise between low down torque and top end revs.
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80461
Well, what do you think, it bloody flies.He cant put his foot down all the way with "normal" street tyres on 'cause it torque steers all over the place! Thats why fast GTRs are so much fun.They are a challenge to drive.The Holinger box is fantastic.Cant wait to get mine.
Nissan "chose" not to put a 3 litre in the GTR 'cause the RB30 does not exist in Japan, & neither did the very expensive 3 litre conversion at the time. You are right - the Australian RB30 will not rev like an RB26, but there are plenty of good engine builders out there that are screwing wild power out of RB30s.
The OS 3 litre engine is not a same stroke/larger bore like the RB30.It uses the same bore size as the RB26, but a much larger stroke(from 73.7mm to 86mm)hence the spacer plate.
These engines are quite happy at over 9000rpm & are extremely
flexible.
There is no such thing as cheating in Drag Racing.First over the line wins.Thats it.Whatever you can do to increase power - do.
More boost, better intercooler, etc etc.The oldest saying in the book is - there is no substitute for cubic inches.
:burnout:
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80583
Me thinks NOS is cheating. Only on the fastest street driven GTR though. The whole RH9 thing, they can do 9's without NOS. But anything else is fine by me. :D
Plus i think ANDRA should change the "street division" rules to only allow street legal tyres. You don't drive slicks on the road, so why should they be allowed in the street class. And while i'm at it road registered too. If you have a car solely used for drag racing, surely it's not that hard to get it into super street class. I know i would be upset to put money into a specific drag only car, and to be shit all over by a GTR that drove there.
(rant over)
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80604
[rant]
The only reason people say that nitrous is cheating is because of it's prominence in TF&F. They don't want to sound like a ricer who loves the movie, so they say that nitrous is bad.
I see no difference between nitrous & any other non-legal modification (which most of them are). What seperates it from a pod filter or dragging without a catalytic convertor?
I would also like to say that there is nothing wrong with being a fan of TF&F, pretty much everyone here is whether they admit it or not.
[/rant]
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80620
Originally posted by cereal_jacques
[rant]
[/rant]
true u cant say nos is cheating!
Nos is just another bolt on modification, otherwise u could easily say using c16/c21 fuel is cheating, running more than ..PSI boost is cheating!
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80688
Nahh - the only reason the 3ltr's don't rev as well is because they flow so much more air at any given rpm. Put some high lift cams with lots of duration, and you'll find that the 3ltr will flow plenty :D
In any case, I'll take you for a spin in my car next time I see you... The redline is at 7500rpm, and there's still around 300rwkw at that point :D
matt
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80703
matt
matt
so what type of numbers u pulling at the wheels these days with the new turbo?
and did u try all these mods with the rb25 block or did u go straight away for the rb30 block?
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80708
Denham,
I'll let you know at the end of the week, I'm taking it in for the final tune this week... :D
Re: Mods - nahh - it was all done at once... The turbo/manifold I've got were bought half way through the upgrade as my turbo at the time would have been too small for the rb30/25 combo.
matt
Originally posted by INASNT
matt
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-80715
I didnt mean to bag the 3 ltr crew, coz I know a few of them (inc Matty) just a spanner to throw into the works. Matty Id love a ride in the beast.
Whan I read Munro's comment saying "There is no such thing as cheating in Drag Racing.First over the line wins.Thats it." I never looked at it that way, thanks mate.
Hope this summer sets out to be one of the hottest for drag racing GTR's.
Which allows an engine to rev harder bore or stroke?
GO THE GTR!!!!
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-81037
My NOS comment has no relevance to TF&F (big fan of this too). it is more a comment on the street class and skyline racing. Also a note to the abilities of the japanese to get nine second times from cars that generally (note..generally) wouldn't look out of place lined up in our street catogory. ie street legal tyres (barely, but still) exhaust, massive aerodynamics, manual gearbox etc etc.
https://www.sau.com.au/forums/topic/5241-ride-in-an-rh9-gtr/#findComment-81912
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
