  • Replies 61
How dodgy is that!
Ive seen car dealer owners and staff thrash the cars so much, we even went to one place and the guy had to move all these cars to get to the one we wanted to test drive, every single car was dead cold but he still proceeded to floor it like a maniac up the street just to turn around and come back again :)
I think knore was more worried about the fact that they were getting into a car with a dead cold engine and revving the tits off.
It might not have been a dealers car but? They could have just borrowed the plate for the weekend to compete in the burnout comp? I think they'd be pretty stupid to try and advertise a caryard whilst doing a burnout at a car event. Just my opinion.
Hey nismogirl no its not a pretty site seeing that being done to somethin i put alot work into and cared about not too sure how old he was id say early 30's from what you saw did it sound ok or was it struggling i do miss the power im now driving (i shouldnt really say) a vn commonwhore on gas all this just to save enough money to buy a house
radiator fluid should be good for 5 years, however u should change if it boils
Coolant should be changed every 2 years, im a mechanic and ive never seen coolant last 5 years. Cooling system flushes cost $88 bucks do that every 2 years and u wont have a problem with the cooling system. General upkeep is the key, people dont spend money and think they have a great car coz they havent had to spend any money on it but then it cost em more in the long run.
Yeah? Both efforts I have done were 1min30sec+ and my temp guage hardly moved at all, but they were only first gear ones, but still yeah had flush slightly after first go, and have not flushed since, so might be a good idea :(
Bah, 1st gear burnouts are for PU$$Y'S!!!!
:flamed:
I was just quoting off the bottle :Oops:
Hey strutto, have u still got that in car vid of my skid? if so can u upload it? I lost my copy :cheers:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
