  • Replies 61
How dodgy is that!
Ive seen car dealer owners and staff thrash the cars so much, we even went to one place and the guy had to move all these cars to get to the one we wanted to test drive, every single car was dead cold but he still proceeded to floor it like a maniac up the street just to turn around and come back again :)
I think knore was more worried about the fact that they were getting into a car with a dead cold engine and revving the tits off.
It might not have been a dealers car but? They could have just borrowed the plate for the weekend to compete in the burnout comp? I think they'd be pretty stupid to try and advertise a caryard whilst doing a burnout at a car event. Just my opinion.
Hey nismogirl no its not a pretty site seeing that being done to somethin i put alot work into and cared about not too sure how old he was id say early 30's from what you saw did it sound ok or was it struggling i do miss the power im now driving (i shouldnt really say) a vn commonwhore on gas all this just to save enough money to buy a house
radiator fluid should be good for 5 years, however u should change if it boils
Coolant should be changed every 2 years, im a mechanic and ive never seen coolant last 5 years. Cooling system flushes cost $88 bucks do that every 2 years and u wont have a problem with the cooling system. General upkeep is the key, people dont spend money and think they have a great car coz they havent had to spend any money on it but then it cost em more in the long run.
Yeah? Both efforts I have done were 1min30sec+ and my temp guage hardly moved at all, but they were only first gear ones, but still yeah had flush slightly after first go, and have not flushed since, so might be a good idea :(
Bah, 1st gear burnouts are for PU$$Y'S!!!!
:flamed:
I was just quoting off the bottle :Oops:
Hey strutto, have u still got that in car vid of my skid? if so can u upload it? I lost my copy :cheers:
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
