Sk are the 260rs suspension the same as the R33/34 GTR exactly the same? Just want to clarify this thats all. Will it fit? And how will it work? Good or bad?
In general the R33GTR suspension settings (both shock and spring rates) are very aggressive. Much more so than the R32GTR, for no reasons that I can discern other than perhaps market perception. When I was doing the engineering on the Group Buy kits last year, I tried several R33GTR suspension kits on my Stagea. I found them to be “out of character” for the Stagea. The extra rear weight, longer overhang and higher CoG made the suspension feel unbalanced. Plus the aftermarket R33GTR rear shocks are much shorter than the Stageas and this caused some topping out problems when the ride height was selected high enough to carry rear seat passengers and or cargo.
So I came up with some quite different settings for the Group Buy kit, using R34GTT 4 door rear and R33GTR front with shock valving changes more in line with R32GTR, Then I used the stabiliser bars rates (particularly the rear) to overcome the extra rear weight, longer overhang and higher CoG.
Depending on the drivers preferences there are a number of combinations that work, the most common one being a trade off of a little handling for a lot of ride comfort. This seems popular with the guys who have rough roads on their normal journeys.
The bottom line, I wouldn’t buy an off the shelf R33GTR coil over kit and expect it to work particularly well in a Stagea.
:cheers: cheers :ban:
thats what i have in mind as well but im still debating on wheter to get a GTR (plenty of choices_ or to get a Tein Coilover type HA for a 260rs (limited choices). From ypur experience do you have an idea of the Teins type HA? As for spring rate front: 10㎏ rear: 9㎏ for type Ha.
BTW does blistein do coilover for 260rs?
Edited by stasis
Keep in mind the standard GTR spring rates are around 3.3 kg/mm front and rear, Stagea RS4’s are slightly less. So 10 kg /mm is around 3 times the standard spring rate, which is fairly typical Japanese. In Australia, a sports spring would usually be 20-25% higher in rate than standard. The shock rates are equally as drastic, in particular the rebound, as an attempt to control the extreme spring rate.
That should give you some idea of what to expect if you choose a Japanese coil over kit. They are all pretty much the same. Plus it will most likely come with spherical bearing in the strut tops, which adds to the NVH something fierce, compared to the standard rubber mounts.
I can arrange a coil over conversion for Bilstein shocks suitably valved, using Eibach (the best) coil springs in equally suitable rates. They enable the use of the standard strut top rubber insulators.
In addition, Bilstein have a high end (high quality) coil over kit with dual springs, adjustable shocks (bump and rebound in one adjuster) with adjustable height.
PM if you require any further details on each set up.
>_< Cheers :wave:
Edited by Sydneykid
  • 4 weeks later...
Well, i can vouch for the suspension upgrade doing its job properly. Although i do have TEIN not Bilstein, i do have the whilteline bars, and also adjustable camber arms. In the brake test, stopping as quick as possible from 60kph, i stopped a good 1m, maybe 1.5m shorter than an MR2. also on the stop and swerve test i missed the cones up to 75kph, which is as good as most small cars. everyone should upgrade from the soft spongey stock suspension and go for some nice tight coilovers and a set of sway bars.
Do standard springs go soft & spongey with age? >_<
IMO: standard springs with the Bilstein shocks + Whiteline swaybars & pineapples is a fantastic compliment of each other.......... the minimum suspn upgrade as such. Not too stiff at 60kph but puuurrfect from 80kph+.
:sorcerer:
Hi Sk,
quicl question. I got my car . Took it for an aligment and guess wat? They couldnt match the camber to both side!! They got close but couldnt really match it. Do i need a camber adjuster? Or from your experience why does it not able not match for the camber?
When they first checked it (aligment peopel) both sides where way off meaning one was like 1. somethin (passenger side) and the right was like 2.0 something)dricers side.
They asked me had the car been into any accidents before and i said dont think so/ What do you think?
Hi Sk,
The standard rear camber adjusters only do 0.25 degrees, so not much adjustment there.
Check the ride height, centre of wheel to guard on all 4 corners. Mine was RHS (drivers) down, 8 mm as it spent a lot of its life with one person in it. Levelled it up by swapping springs around and the camber was then even.
Post up the ride heights and we will go from there.
:mad: Cheers : D
haha, you wouldn't believe it if i told you. i won't be able to get onto it for another few weekends now, i don't even have time to scratch my own nuts. i haven't forgotten however, leave it with me
Hi Sk,
got the maesurements today. both fronts are 350mm and both rears are 347mm. Let me know if you need additional info. thanks
That's pretty low, at that height the camber goes a bit all over the place, 1.75 degrees one side and 2.25 degrees the other is not so bad a difference (I have seen worse). The standard adjusters are good for around 0.25 degrees of adjustment. So you should be able to get the cambers a bit closer together using them. ie; take some off the side with 2.25 and add some to the 1.75. Although 1.75 is already too much.
My recommendation would be to get some an adjustable camber kit for the rear and most likely one for the front as well. This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 390/385 mm front and 280/375 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Details are in the Group buy thread
http://www.skylinesaustralia.com/forums/in...showtopic=85592
Hope that was of some help
;) cheers :wave:
Anyone have or tried KYB shockies in their Stagea, putting in a set of KYB "New SR Special" with stock springs. Not after a train on rails, just a nice stock feel.
http://www.s-ds.cc/product/201
  • 3 weeks later...
is there any simple/not super expensive way to adapt the rear links of an RS4 to take coilovers designed for an RS260?
Got nothing to do with "rear links".
The 260RS uprights are R33GTR, the shocks bolt to them. So you would have to change the uprights. But that also means changing drive shafts, diff, cradle, brakes etc.
Have a look at Brad's thread on swapping the R33GTR rear end into his Stagea
That's basically what you would have to do.
:laugh: cheers :(
PS; why would you bother anyway, there is nothing great about 260RS shocks
  • 3 weeks later...
i'm actually made of sugar, so yes i melt in the rain.
no, i park in a dirt carpark at work, so i'm not about to get on the ground underneath my car.
....is it stil raining..... :)
............still raining......................? :D
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
