Here they are in a NISMO catalogue.
The complete coilover they are from are sold here, http://www.perfectrun.com.au/performance%2...attackrtune.htm
SPECS:
4WD(A/T車)用 ノーマル形状減衰力固定式
車高変化代:Fr 約-30mm Rr 約-20mm
バネ定数:Fr37.2(3.8) Rr43.2(4.4) N/mm(kgf/mm)
....anything else :banana:
  • 4 weeks later...
was just wondering if anybody could let me know what front sway bar a (RWD) stagea uses. i know the AWD ones use a GTR bar but im just wondering if i would only require a GTS-T sway bar. i really need to upgrade the sway bars as my car didnt even come with a rear bar at all and i want to do both at the same time. cheers for any help.
Has anyone replaced JUST their springs?
I've got healthy Nismo shocks, but jeezus, I can get 4-5 fingers between tyre and guard all round.
Can I use R33 GTS-T springs? GT-R springs? Want to get it down minimum 50mm or so. Probably 60+.
Nope, but I've got standard s1 RS-Four springs for sale if you want them...
Are there mounting holes for the rear ones or are you saying your model never had any?
I think (these are old whiteline refS) Rear: BNR11XZ (22mm adjustable) and Front: BNF27 22mm or 24mm - whatever is an upgrade for you - but try to get hold of SK - he is the expert and makes them under the Selby brand I believe at Superior Suspension in Sydney.
yeah i have mounting holes but it seems to be a hit and miss with the rear wheel drives if they have a rear bar from factory or not. i have tried sk but he gets busy sometimes. might try and ring his work shop then, cheers.
ps. im pretty sure that front bar ref # is for an AWD/GTR front sway bar which i assume is completly different to my front end as the front struts a very different also
That's true, the front suspension on RWD's is completely different, so I wouldn't be surprised to find that the stabiliser bars are different and/or attach to the body or suspension in a different way.
  • 3 weeks later...
Hey guys..
How hard is it to install Tein Super Wagons on a S2 Stagea?? Can it be done with mates or should I take it to a suspension place to do it.
Reason is that I'm might be looking in getting either Tein Super Wagon or Tein GT Wagon coilovers.
I've got three places where i can do it
1. mates backyard (have jacks and tools - very backyarder)
2. mates workshop (many tools and hoist)
or
3. Take to a suspension place and get them to install it
What should I do...let alone what set of coilovers to buy???
Hey guys..
or
Number 2!! i went with the Tein Super Wagons, did mine in 45mins by myself! didn't even have to take off the wheels!
Hey guys, I have done a search but I can't find any details.
I am after setup details for a wheel alignment for my brothers stagea. He has a S2 RS4. It is sitting pretty low (310mm Centre of the wheel to the guard) and has some massive camber (will be getting fixed soon).
The car goes in tomorrow and I would like to know what the best setup would be.
Cheers.
Sydney Kid Please Check Your Pm's AS i still have not recived my Refund for the caster and camber Bush's and it has been a month, after being told they where on site and would be in my hands in 1-3 workin days and waitin 2 weeks because of "Stock being sold" after i already paid for it. i have talked with Matt Cook and org'd a refund for $302 mid Aug it still it has come to nothing.
Due to your trader rating i thought that this would be a clean sale but has turned out to be SUS.
i dont know how you guys run things but by anyones standard this is bull shit and expect this to be sorted ASAP.
You have my contact details, use them as i dont have the use of the internet to often as discussed in my previous pm's
Cheers.
I think its in the Whiteline gruop buy thread but it goes like this:
Front:
Caster Left: as much as possible (5 deg or more
Caster Right: whatever you got on the right less 1/4 degree (to allow for road camber)
Camber L&R 1 deg negative
Toe in L&R zero
Rear:
Camber L&R neg 0.5 deg
Toe in L&R minus 2mm
Hey guys, alignment has been done. The camer is rediculouse and will be fixed as soon as my brother has the cash.
Can you let me know if there is anything wrong with these settings.
Cheers.
wheel_alignment_20080829103041.pdf
Cheers.
All OK except the camber F&R
You can't get enough adjustment so you have to get the adjustable bushes - some one was selling a kit on this forum (cant remember if it was front or rear).
Cheers.
These figures looks very familiar. Almost like mine when i got the car. The rear camber.
For the Front:
Get a camber kit (outer). Thats should gives you around 1 deg adjustments.
For the rear :
1. Get an adjustable arm. i think just jap sells them. That should take care of the problem. If you use the Camber bush kit you will never get enough adjustment just by using 1 kit. If you use 2 kits, i rahter use the adjustable arm to save costs.
Hope this will help you.
ok, so i asked a few weeks ago if anybody knew what sort of front sway bar the RWD spec stagea used. not getting much confirmation i brought a GTST one and decided today to have a fiddle. well as it turns out i already had a 25.5mm sway bar on the front not sure if this is standard or not and it was solid also so i decided that i would leave it on but that is not before i took it of to compare the two. as u can see from the picture they do vary slightly but i think it would bolt on if u turned the end links around so that they faced outward instead of inwards.
i also got busy today and fitted the heavy duty sway bar in the rear which is great as i didnt have one fitted at all. my Kei Office coil overs arrived yesterday and i put the front ones in today and will do the rears when i get a chance but already im looking for bigger corners to go around fast so i cant wait to put them in also. found out today that the rear tyres are well scrubbed on the inside so im in the market for some rear camber arms and im going to do the front castor arms also and i think that will just about do it.
i just took delivery of some tein dress up master lowered springs, i will be getting them put in on tuesday still with my factory shocks which are in immaculate
condition, i will let you guys know after what it's like.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
