i am looking at the hks hiper damper kits. The seller has told me that the R32 one won't fit, but that the R34 one will. They are second hand on eBay but they look in pretty good nick, say they have no leaks and the seller has a good rep.
Is the seller right about the R34 ones being suitable for my stag?
You are better off looking for a Stagea kit. There is so much more glass & steel behind the rear wheels on the wagon, even if they do fit (all depends on model) the spring and damper rates at the rear will be for a car that weighs 300kg (approx) less.
Ebay sellers will often tell you what you want to hear, to make a sale. Buyer beware!
Edited by Daleo
Cool. I had wondered about the extra weight, and a seller wanting to make a sale, which was why I thought I'd ask on here. Thanks for the help!
No worries, this forum has saved me plenty of money . :thumbsup:
Unsure of your budget, but maybe have a look at BC coilovers. Excellent value for money.
I'd been looking at BC, but am not sure how much budget I'll have left after putting a Nismo chip in it, plus exhaust, but I'll see how I go. I was just so tempted when I saw the HKS ones so cheap!
Hi after reading the whole 43 pages of this thread, im still unsure wether the R32 GTR shocks on the front and R33 GTST on the rear will be suitable to the weight of the stagea or not? I know there not perfect but will they be okay?
If anyone can tell me if they have used shocks from the 32 and 33 and how they went, it would be great.
Cheers
yep gtr (or gtst) front will fit & r33 gtst rear will fit with a bit of work (rear top hats are different)! As for spring and shock rates, if you are using adj coilovers then it wont be a problem, but stock items wont be perfect, but are still quite usable!
* only the factory fitted manuals (ie: 260rs & rs4s) use the gtr style rear fork!
Edited by Zorro
So what to do... after having the stagea lowered I am now faced with a choice... continue to replace the castor and camber bushes every 20 000 kms... or raise it... :(
But it is sooooo pretty this low!!!And I want more aggressive castor.. not less!
seriously...how much worse are uni-jointed castor arms tna bushes... I know they make noise when wet but is it really worth being concerned about...?
and and what is the minimum height I should cut my bumpstops???
*end rant*
@captinsane, what brand bushes are you using? you could use those pillow ball/solid mount/uni joint/shiney metal style adjustors but they require more maintainence (cleaning and re-lubricating etc)
also any modification to the bumpstop is illegal in any state so if you need to pass a rego slip soon i wouldnt unless you go spares. dont get me wrong my vw touches the ground with no bumpstops so i love lowered cars but yeh id either pull em out or find some GTR ones to cut.
Hi guys , i've got myself a s2 RS-v rwd 98 wgc34, an i have got myself some ISC coilovers but the fronts dont fit. the cars top mount has 3 bolts an the base mount is the same as a holden mcpherson strut, the guys at isc r not to sure whats going on. can anyone help? the stub axel has a lower control arm, tension arm, sway bar and the shocky. help.
I also have a 99 RS stag that I am hunting shocks for. Don't know if to go cheap BC coilovers or a Bilstein or kyb shock? I really want a nice comfortable ride and a guard height of about 360 ish.
Any experiences?
Cheers
Any experiences?
Cheers
i've been running BC's for just over a year now and i'm happy with them, i haven't had any issue's. the guys at justjap recommended them to me and said they had a few customers running them in their stagea's and had only good reports about them. from memory the springs are only a bit stiffer than stock, something like 8kg front and 6kg rear. i only have the dampers set to half way and the ride is good. i do a few road trips a year, sometimes with the car fully loaded, and with the exception of a few bumps that would be harsh on any suspension, the ride is comfortable. i've taken the stagea on a couple of twisty mountain runs too and it handled really well.
just got a 97 stagea rs4 and my rear wheels are sticking out a mm or 2 and i need to get stock rims for it or does anyone know what stock rims can go on stageas like r34 maybe r33 etc
do you have plans to lower your car? when you lower it the wheels will pull in a bit and wont stick out as far.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
