saw a red stagea with plates "STAGEA" on orrong road about 4pm yesterday, some older woman driving it with kids i think. stock as a rock :D
If this is the same car Brad...with red number plate it is actually a guys on sau (from WA)....he is actually selling it from memory!!! I asked him if i could buy his number plate off him and he said if i give him 16k i would get his car free...hehehehe :(
just back from car show at Parklands on Gold Coast. Did not see a single Stagea
Lots of Skies Sils & 180's and one Cifero.
Very disappointing!!!!!!!!!
When are we going to exhibit? Or do we keep it to ourselves?
Will there be any Stagea's at the Melbourne Auto Salon?
Next weekend (29th - 30th April)
Would be nice to see something there, the only Stagea I have seen in the flesh now belongs to Humble... I should see mine arrive this week though so I will be fairly enthusiastic by then!
Cheers
Luke
Luke,
Mine will be there on the AXS stand, which l believe will be next to the main stage. But l personally will prolly only be there late sunday afternoon (oh & fri night).
Make sure u take lots of pics!! :D :D :D
Edited by [ STAGEN ]
' date='23 Apr 2006, 04:20 PM' post='2110830']
Luke,
Nice work! Anyone else?
ouch thats gotta hurt, i must say thats a fair effort though, considering you were just about sitting on the speed limiter
yeah... well to recollection i was cruising on the limiter (fuel cut off a couple of times). ADR allows speedos to be within 10% accurate, which comes into play the faster your going, so yeah. id say i was cruisin at 180. Im not thrilled about the whole situation, but yeah. they should raise the speed limits between 1 and 5 in the mornings on that stretch of road! haha ive never seen such a tiny picture of a car in one of those photos but... i was pretty far by the time its shutter snapped! :whistling:
ps i am a big fan of your front bar - its a 260, right? really big fan. just had a Nismo one fitted. pics soon, as well as the rest of the kit.
and techo - shall scan, shall post, shall be laughed at lol. at least i know all my tail lights work wonderfully. and my number plate lamp must be BRIGHT as a MOFO cos i dont remember a flash.
Edited by qikstagea
Yeah series 2 260rs front bar, if only i had the sideskirts to match :whistling:
spotted silver s1 stock as a rock drivin along the foreshore in newy late sunday arvo.
caught me by surprise as i had not yet spotted any other stageas wen i've been in mine.
i'm sure the fella behind the wheel was just as shocked.
pretty sure it had qld plates on it
Spotted white series 2, came through drive through at work, I said nice Stagea, he said most people dont know what they are...
So i asked if he saw mine parked next to the menu board. lol
Was very neat with leather. Sweet lookin Stag
Spotted a light green Stagea turning off Parramatta Rd today around Haberfield, approximately 12.30pm. It had an extra pair of driving lights in the bottom of the front bar, but looked otherwise standard. Was being driven by a female. Soccer mum, maybe?
Unfortunately, I wasn't in mine at the time.
Stageas - you want stageas. We've got stageas everywhere - I've got a silver dayz S1 with chrome rims, black spokes, lowered, full stainless ces system and little green lights under side mirrors and just down the road is a silver S2 rwd fmic and big turbo and a little bit further down the road is a white S2 with bodykit. Not to far down the coast is a yellow S2 with body kit. So the far north coast of nsw is stageaville.
Happy trails, see you on the road. pics coming soon .............................
leetom :D
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
