MY MUM SPOTTED CYRUS near the highway at burpengary. and i quote -
"he had a wife and kid/s... had dark hair. car was gunmetal grey, a manual, and a loud exhaust'
lol figure thats gotta be you, man.
Edited by qikstagea
Proxy spotted: An ACT SAU member spotted Marc's white S2 trying to make it with an Echo yesterday morning. He's ok but the car is a mess, no info on write-off or not, i'll let him tell the story.
Spotted 3 Stageas in the space of 10 minutes - getting common now !!!
One is a white Series 1 near Baby on a Budget in Joondalup - owned by the manager there.
Then as we drove from there, saw a green Series 1 heading West along Ocean Reef Rd near Woodvale, then an awesome white Series 1 with a great body kit stopped at the lights turning right from Wanneroo Rd into Ocean Reef Rd - this was all around 2:00pm today
Spotted a Silver S2 Stagea, on copland dr around 10 to 6, turned left at the college, I was in the blue r32 4 door, don't know if you saw me , i was behind the 4x4, still nice looking stagea.
Was probably me, i live up the road there. mine is a S1 sorry to disappoint, but i have S2 taillights & Autech wing :ninja:
Spotted yellow Stagea going through the lights at Joondalup Dve and Ocean Reef Rd (just in time before the red light) - was in mine and gave a wave but probably didn't get seen (or just ignored !!!)
Cheers, Al
Spotted STG.34R in east maitland, silver stag the same as mine had S2 tail lights, can't be sure these days s1 or s2 , but is was RS4 had a big cannon n HKS sticker, it was raining too the 4wd would've had me, not sure if he seen me tho
Spotted a Silver S2 in east maitland today while going into greenhills.
That's right, i'm in Maitland for a couple of days, keep an eye out ;)
call into hassall grove on ya way home just jump off m7 at richmond rd and ya there at mikes house lol or gimme a ring pm me for my number if you get time :)
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
