Last week, middleaged woman in burgundy S1 pulled up next to me at the lights on rosanna rd. Bit of a chat, not often two pull up next to each other..
LOL the good wife was horrified to see middleaged woman there... lookout if you cross paths again :D
got it off ebay, i also have a japanese fire truck model.. i have to put them together when i get time..
saw the white S2 with black rims again the other day on heatherton road, pulled up abit behind me...
Hey mate i had a look on ebay and can only find some from Hong kong for like $90 ish (15 pounds plus shipping) bit Xy for me i think
hey Nick you get spotted all the time by a colleague of mine. It goes like this "hey i saw a wierd car like yours but green on old windsor rd this morning". Watch out for a wierd stalker in a black golf
I do? Sweeeeeet! :)
Are you still working at the same place, Duncan? I've been spending a lot of time out that way because it's so much easier to shop in Winston Hills, Castle Hill or Baulkham Hills instead of fighting the masses (and the idiots) at Parramatta.
What series Golf is it? Mark 4 or 5? Basic model or GTI (or R32 :banana: )?
prolly me i drove down most of penno hills road this morning about 9am and then back again about midday. What were you driving jetwreck? spewing if i missed an m35 ont he roads
nick - i didnt ask it was a vw so i couldnt pretend to be interested ;)
Duncan....I was in a Black M35 ARX.....If you were in the white Stagea you should have heard me I was right next to you tapping the horn as I went past the entrance from Castle Hill road...maybe you had the Spice Girls pumping on the stereo and didn't hear me...lol.....might not have been you though.
I hit Pennant hills Road at about 7.45 to 8.
where were you Lanky? didn't see another stagea apart from Nick's today?
Umm... I'm not a Stagea... rather a silver 4 door R34... I will have to come up and introduce myself to you next time. But i post in the stagea thread as I spotted stageas lol.
Were you around near MRT at Rhodes last Wednesday afternoon. Saw a Black ARX go past me while sitting in the crap traffic that day just around the corner from MRT. I am in a Silver ARX.
Cheers
Andy
You got my cherry(first time spotted...took three weeks..lol)....I work in Rhodes....missed the Silver ARX though : ( .
Gotta love the traffic around there aye!!!!
Usually not so bad for me as I head south in the morning but that day was the pitts. 2 km's in 40minutes!!
Is your car stock or have done some mods yet? I want to talk to some one who knows about suspension for the NM35 as I would like to improve mine.
I'll have to watch out for Lanky as I live in West Ryde.
Yeh I have done the exhaust and wheels so far....Going to get the Turbo pulled out then Ballbearinged, highflow and steel impellered next year....then a booste controller and booste gauge put in to get it up to about 13 to 15 PSI....will see if it needs the intercooler after that.
With suspension there's a mob in Perth(contact ausis)....I am trying to locate someone in Sydney....problem is I don't know wether I want to part with $1,800 for coil over's installed just to go down 2 or 3 inch's if I am never going to take it on the track. Would prefer to spend it on brakes as the stock one's are crap.
Andy and Jetwreck, you should come to the Coastie meets on Thursday nights - I'd love to have a look at an M35 in the flesh too!
Not sure I can make it but where and what time Thursday? What are the "Coastie meets"?
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
