Wooooooooooooooooot, I finally spotted my first other on the road Stagea! *happy dance*. I was running late for a doctors appointment yesterday arvo around 2:30pm, but I noticed a stag leaving the pakenham lakeside estate, so I decided to chase them down. Ok, dont laugh, the details are sketchy because I was running very late, and mostly because I was so darn excited! It was white (or maybe silver.... *rolls eyes*) and a very tidy looking S1 with number plates along the lines of UYL*** or UVL*** or something like that. Anyone on here?
Edited by Qumulys
My sister tells me she keeps seeing a white Stagea around the Toongabbie (NSW) area. She's not sure if it's an s1 or s2, but she has been learning pointers on how to tell them apart, as well as the different Skylines and Silvias.
Spotted Yesterday:
Stock white C34: not sure if S1 or S2, heading towards Neilsens Rd in Carrara, around 2pm.
Then we saw a M35 (silver?) heading North on the Pacific Motorway, Northbound. It was stopped at the traffic lights outside Coolangatta Airport, at around 4pm.
Last night went down to Victor harbor here in SA....
On arrival I saw a stock silver S2 stag at the BP, was for sale on here by pirate or someone as I spoken to the new owner... she had no idea about them at all :happy:
On the way home today saw another silver series 2 stag near the turnoff to victor from south road. I would have waved but was mid song change when i put mny head up i noticed it in the corner of my eye...
not a stag but also on the way home I saw a sexy bayside blue r34 grt vspec :wub:!!!
yeh. i have seen that silver one on top. its nice. but lately i have seen a few. there was this yellow one with a milo tin. it was nice. it was up at some pub.
here is one i found not so long ago..
if the person that owns this one. i found in bassendean on fri morning at edan hill perth W.A
if you can please reply :happy:
spotted white series 1 RS260 tuesday at 1,30/2pm turning off REID hwy on to Alexander drive no sure if they saw me sitting in traffic at light`s on reid hwy heading toward`s midland ??,cheer`s chuckie.
Spotted a black M35 ARX this morning travelling east on Boundry rd Chatswood. Turns out it was Jetwreck.
Looked very strange having a M35 coming up from behind my own M35....
Edited by andy65b
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
