Spotted a wine red s1 today, plates were JAG75B. This was on Seven Hills Rd/Prospect Highway just before midday today. I beeped and got a wave back!
I've seen this car before but it was quite a while ago.
Spotted, silver s2 on GWN 6pm news wearing the dreaded P plate. Twice! :woot:
S'pose it will be picked as a Volvo by the masses.
Cheers GW
Edit: GWN=West Aust. country TV station for you foreigners.
Edited by 260tech
Spotted 3 Today:
First was a silver/grey S2, heading north on the Pacific hwy: it took the Elysium Rd exit at Worongary.
Second was a S1, Grey with shiny dish rims and a front mount at Shell servo, Mudgeeraba: I think it's a Hungry Jacks staff car, as I've seen it outside the Qstore Hungry Jacks a couple of times before....
Third was Deminiak, when he came to visit this arvo: Very nice red RSV, now with leather interior :)
Spotted, silver s2 on GWN 6pm news wearing the dreaded P plate. Twice! :)
Cheers GW
It even made it on Channel 7 in the big smoke!
richard
richard
That was my Stagea. My wife works for Channel 7 & they wanted to use the car to demo the new P plates. Not so sure I like the idea of using my Stagea as a 'P plate' demo though. Oh well, its a celebrity now!
Edited by G*4Stagea
spotted 2 stageas today.. silver series 2 going along portrush road towards nowood parade.. lookd stock but sick.. and was driving in a side street b4 to c another wags parked... reversed to find my self a nice hot s1 mint as... gave the dude a spool up (was watchn tv in front room ;))
Spotted a white M35 on Parramatta Road around Leichhardt as I was heading into town for the Sydney Auto Salon. It was heading west-bound, around 12.30pm or 1pm.
Also spotted Xmetal's car amongst the SAU display @ Auto Salon.
pretty sure it was white- cant remember... It was at a round about so i'm pretty sure they would have spotted me too hehe
i live in carrara- who is your mechanic?
Spotted a silver stag with GTR badge (i hope you have a RB26 in there hehe) turning onto broadbeach-nerang road from ashmore this evening around 530- tried to get up next to you at the lights but didnt quite get your attention
Would have been mine: I use Ultimate Performance & 4WD in Jaygee ct. May have been a mech on a test drive: I try to keep my eyes open for other stags... :D
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
