That is so WRONG!!!
How's the Mister Spyder, James?
Pretty good. Finally heading out to the trackday at OP in early September so I can push the car to the limit. Would be good to see some SAU people there too.
Spotted a M35 on my way to work this morning around 8.25am.. I was heading towards parramatta on victoria rd, he heading towards the city! He beeped a couple of times as I was in my S2 Dayz.. I was actually wondering why the hell someone would toot at me, then I realised he was driving a stag!!
So Mr M35, if your reading this.. In the words of Road Runner himself.... BEEEP BEEEP!
ahh!!! so you were in the Yellow S2....nice ride mate.
Also might add....Spotted a Yellow S2 on my way to work this morning around 8.25am.. I was heading towards Rhodes on victoria rd, he heading towards the Parramatta! I beeped a couple of times but he seemed to be in a Dayz! He was probably wondering why the hell someone would toot at him....lol....probably see you again soon as I do that route every day.
P.S. I know I'm lazy and I should start typing my own shit rather than cut and paste.
HaHaHa!! The funniest thing is... I was in such a dayz this morning!! HaHaHa! I've worked the past 15 days straight..
Yes, I also travel that route every day myself! So next time you might just get a toot back!! HaHaHa!
Nice! More Sydney people to pester/stalk for when I arrange a Stagea cruise when the weather starts to get warmer!
Not a prob.....soccer season is nearly finished so i'll be in for a Thursday night cruise/catchup.
volvo driving soccer mum :)
lol.....bitch!!! :huh: I wish I had a dollar for every-time it's been called a Volvo.
oh yeh.....any luck with finding the r32 rear's?
Edited by Jetwreck
Weather gets warmer?? Ah, bugger that!! Its better when the air is nice and cold! No reason you couldn't organise one now!
Yeah, I know - the cars love the cold!
But I don't drive too well when wearing 15-20 layers of clothing - I'm a skinny mofo and don't cope too well in the winter weather!
Fellow gold coasters- we should organise a cruise sometime this week seeing as its beautifully warm up here :) hehe
Fellow gold coasters- we should organise a cruise sometime this week seeing as its beautifully warm up here :ermm: hehe
Pfffft!! XXXX drinkin, kane toad whacking, hippies!! HaHaHa! Jokes! :blink: Yes, warmer weather would be nice! But.... Sydney isn't cold at all!! This is cold!
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
