Spotted Alex "CL11QE" outside my house about half-an-hour ago!
Sweeeeet! Sorry i couldnt hang around dude but the missus was starvin n the little one was
gettin a bit rowdy!
Then i guess spotted Nick "GoldZilla" in his garage :laughing-smiley-014:
spotted a silver M35 ARX going around the peanut at midway shops this morning around 7.55. tried to catch up but there was WAY too much traffic
Now you have seen my car.................
You must have been stuck in that line of traffic on the Eastwood side.
yes i have!!
and yes i was, drove out of my driveway and stopped lol
i should really leave 10 mins earlier and beat that traffic. today i didnt sleep in long enough to completely miss the traffic all together........
yes i have!!
I usually go through that roundabout between 7.40 - 8. Unless I drop the kids at school on Terry's rd at 8.15.
i dont have a job for much longer, so im not taking any chances getting stuck in that traffic every day. so i make an executive decision and go in late every day. had to go in early today because my laptop was arriving lol
that doesn't sound good. Sorry to hear that.
But new laptop and job going soon... sounds like the result of this recent colapse..
thats what happens when you work for a US multi-national. lucky i work in the IT department so ill be here till mid-ish next year.
still doesnt mean im going to work hard till then :)
my redundancy/retainer will pay off the laptop and buy me some camera gear too. and then some mortgage...
spotted a white series 2 on katoomba st in katoomba this morning at approx 11am, i went up for the weekend and it stood out so much when compared to how many
holdens and fords that outnumber the cars on the roads of blue mountains
haha how did we not cross paths - Kel and I were up there for the weekend too (in the Z though).
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
