Quite sure the kit I've got is dolphin, yeah. When I bought I was told nothing about the kit and assumed it was a factory option.
P.S. The fox was basically no more. A bloody mess on the road behind me. I was going around 90kms. Somehow managed to avoid getting blood on my car though. Haha.
Edited by Unbalanced
I keep spotting a Yellow S2, I am positive it is the only Stagea in Rocky now, and I also live just around the corner from him, so I get all nostalgic some mornings and take the long way to work, just to pass it.................................... god I miss mine :thumbsup:
I keep spotting a Yellow S2, I am positive it is the only Stagea in Rocky now, and I also live just around the corner from him, so I get all nostalgic some mornings and take the long way to work, just to pass it.................................... god I miss mine :P
Time to get back into it then? Stress & depression is to be avoided at all cost, very bad for your health & difficult to cure without back-traking to happier times, or so I've been told. :thumbsup::P
Cheers GW
Nah, my next import will be a 2007 or 2008 GTR, plain and simple :thumbsup: Also I bought my 7yr old son a motorbike, so now I need one so we can go exploring trails and stuff :P But there will always be a soft space in my heart for my beloved.............. but onward and upward :P
I rarely post on these forums, but I came out from the shops today and there was a yellow S2 parked next to me! Armadale Shopping Centre (Perth). Took some pics. :D
I have seen this one around a few times.
That's Chuckies Stagea isn't it? The yellow one i mean.
It looks firmiliar. There is a Silver 1998(?) S2 that's parks outside my local Jesters pies in Malaga (Perth). I've parked next to him a few times to try and get a reaction, but so far nothing.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
