Spotted last night (sat) pearl white dayz series 2 on susex street, cant remember what time i think 9.30ish pm had chrome 19's by the looks of things and a front mount.
it looked very nice, i was in the taxi next to it going back towards george st.
Edited by alu-siv_stagea
Spotted 2 stageas on the weekend
one silver ( very clean ) s1 outside cannington Fresh just before 7pm
also saw a ( pretty sure it was ) 260 RS just near bunbury on Saturday around 9 in the morning I suppose - he came up next to me and gave me a wave >_<
our car was disgustingly dirty so I didnt feel very good reprazentin the stagea crew
also saw a ( pretty sure it was ) 260 RS just near bunbury on Saturday around 9 in the morning I suppose - he came up next to me and gave me a wave :D
That was me!!
I pulled up to the lights and i was like wtf someone stole my car, oh wait im in it.
It wasnt that dirty!!
hey man :D good to meet you - Lotty pointed you out and we were wondering if you would catch up and say hello .. the 2 cars did look pretty identical - expect ours is missing a turbo and 100cc displacement haha.. how many kays do you get out of a tank before your warning light comes on ?
we got 450 out of the last tank ( 30 / 70 country and city driving )
That was me!!
hey man :( good to meet you - Lotty pointed you out and we were wondering if you would catch up and say hello .. the 2 cars did look pretty identical - expect ours is missing a turbo and 100cc displacement haha.. how many kays do you get out of a tank before your warning light comes on ?
Happy to see another nice stagea in Bunbury. I had to try and catch up for a look :D
I get about 450-500k's yeah country driving, when i drive my car to work (up the collie hill) i still get the same. Around town though id be lucky to get 300k's. Go's in for a tune next monday so hopefully be beter after that.
so must be the case that on long trips we get much better fuel econ.
yeah we do mostly city driving and usually get around 320-380 k a tank
My best mate rang me today and told me he'd seen a Stagea with a different-coloured door and front guard in his travels around the North Shore, we're guessing it was the victim of an accident.
My sister also mentioned she saw a white Stagea today on the way home from work in Epping, and it went in the same direction as her along Epping Road, Beecroft Rd, Carlingford Rd, onto Pennant Hills Rd towards Parramatta, before turning off into a residential street.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
