iamhe, you drove right by my place and didnt call in for coffee? Werent you going to drop off that Emanage ultimate too? :rofl:
I may... for a price.
Had my wife with me and we both had to go back to work, so no coffee.
Maybe some other time, bud?
Spotted Scotty NM35's Stag... in his driveway.
Nice car bud, Love the FMIC setup & throttle body pipe (but you knew that already) f*ck'n loud exhaust though!
(You would love the exhaust Iain/Craig!)
Edited by iamhe77
lol...gayness calls coming from the gay silver poverty pack twins.....one of them undergoing botox on there headlights and other parts!!!
what is it again Ian????...."When I get gay, I stop being gay and be an awesome homo instead. True story!"
P.S. If I was going to turn it would not be for a male 6ft3" Clayton's Volvo driving mad scientist....Ian's much cuter because his small!!!
P.S.S. There, I have insulted three people in one responce!!!...and I wonder why people think I have an attitude problem!!!! :)
Edited by Jetwreck
and it goes P.S. then P.P.S for post post script dumbass
like I said gay!!!!
Maybe I should I record this day of the month in my diary for Mr Happy!!! :) you've had a go at everyone today!!!!
.....been pissing myself laughing at some of the responses you've given today to overnight experts!
geezus, remember OUR conversation about the exact same topic? lol
anyway, ill concede defeat on that subject with them. but ill be wasting my money on that non-mod in the coming months
Will tell you one thing...I have done 2 throttle bodies....one on a VR HSV 215i(change to Duel Plenum...big improvement in throttle response but car was NA)....and one on a Turbo XR6(not a big improvement but definitely noticeable).
:P:D:(:laugh: Silver? :huh:
Bit sensitive there Craig?
Perhaps there is more to this than a quiet joke!
btw, your display of jealousy of my to-be headlights is quite obvious, Mr. Pokemon lover :P
Edited by iamhe77
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
