no spottage on my venture to falls creek last week :) but last night in my home town of the mighty panthers, Penrith. spotted the same white s2 i keep seeing with purple number plates driving out of the plaza... the lady seen me before i seen her but i still had enough time to get out the window with the big woot woot... the missus thought i was crazy but what the hey...
i'd like to go on a meet some time soon... hopefully my r31 will be done in a few months and ill be able to take that out
p.s. attention anyone who plays for the panthers tonight, give em hell :down:
Edited by Space Goat
that was me
Actually it might not have been me. Was it a dark green with a N/A grille or light green with stock grille? I dont remember waving yesterday, but I did last Sunday to a Magna (?) that flashed.
I also see a grey S1 almost every day at the Tallai shops, which I assume belongs to someone who works there: will have to investigate further and see if a) They are aware of us, and b) if they want to join us for the September meet...
it was light green :( didn't see the grille... they were very happy though :P
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
