Three. I live on the coast (mapleton)! I just mentioned Brisbane as I've been doing a ton of driving in Brisso lately.
Never seen you, but I've seen the burgundy arx. They didn't wave back to me :laugh: I saw them out in Kawana.
I'm up in the hinterland but do cross over into kawana a few times a week (work) and to the beach (maroochydore) once a fortnight or so.
I work at kawana (good guys)but live in currimundi.Anytime you are up for a chat pop in to g.guys i'm graham.I usually leave the stagea home and take my bluebird attesa to work.
The bloke with the burgundy arx has only purchased it recently.He is a newby to this scene but a really nice guy./just keep waving!!!) :)
The bloke with the burgundy arx has only purchased it recently.He is a newby to this scene but a really nice guy./just keep waving!!!) :ninja:
Ahhh, nice.
If I am ever in the area I'll come say g'day, if you ever see me feel free to approach. I'm socially retarded but always nice to meet fellow stagea owners.
I'm almost gauranteed to have my dogs with me, usually heads out the window :) Don't do what the morons at the petrol station do and try to pat my shepherd if I'm not there though :ninja: You'd be surprised how many people see me get out of my car with my SECURITY shirt on and then try and pat the big, black, muzzled GSD in the car.
Have you seen another stagea mate? Perhaps you are blind as well. lol :D
Haha! Yes Graham, always on the lookout.
I spot white and silver C34's around my area and have even spoken to a couple of the drivers (shopping centre carpark).
Too bad they don't jump on SAU
Oh, and there is nothing like seeing a fully loaded up 260RS flying through a roundabout on the way to a camping spot... The roof racks had to have been stacked 600mm high!
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
