spotted white series 2 on bruce highway /coming between caloundra to bris. waved to passenger/got the nod.about 11am Christmas day- drove together approx 60 ks.
2nd spot also white series 2 rs on return journey out of brisbane just out of aspley /coulnt get to wave/flashed him just looked as he turned off at burpengary turn off. :)
spotted what i think was a dark green s1 on the m7 yesterday evening, around the m4 area i think, thought it was maybe Nick but looked like it had those
baby screens over the back side windows.....
Nope, wasn't me, mate. The only places I went on Tuesday was all done in my old man's Audi - went to Hornsby and then Chatswood, so nowhere near where the M7 and M4 meet...
Could this mean my car has a twin in Sydney?
I forgot to mention that on Tuesday night I spotted a dark (not sure what colour, noticed it at the last minute, and it was dark) C34 Stagea on Greystanes Road in Greystanes - it was around 7.30pm-ish.
ooooooooooooooooHHHHhhh, havent been on here in a while.
if that wasnt me i wont be happy :D
first spot, was it driving or parked. i live on greystanes rd and own a black s2 with darkkkkkk tint :P
Yep, must have been you, Andrew. I was going past the speed cameras near Pemulway (sp?), if I remember correctly.
saw a White S2couple days ago, station st seven hills, i flashed, got a wave.. nice and clean!
A white s2 in my hood? I've only ever seen Alex (CL11QE) on the odd occasion that he's been on his way to or from my house in a white s2.
