Dude, you had two s1's right in your neck of the woods last night - we had a dyno day at Unigroup and went to Fully Tabouli at Pemulwuy shops last night afterwards...
think its time i came out of the shadows and said hello to some members
i parked my car at pemulway last night and some kids are going
" brooooo that station wagon is turbo " "what the f**k is it"
im glad they didnt realise i got out of the car
Today I spotted three dark green Stags.
First was in Ashmore Rd
Second parked in construction site near Aussie Fair
Third was in my garage.lol
We are not the only ones Nick!
spotted an m35 broke road in pokolbin (hunter valley vineyards) with the plates ST***A looked sweet, i have seen this before i think at one fo the meets/shows
and got a wave from white s1 in lochinvar on the way home, 2 in the same day lol
That would have been Iain (ziel20l), must be a dirty weekend away with the missus!!
Busted! :nyaanyaa:
Probably even worse if he didn't take his missus, could be some gossip on this one.
Nice spotting :nyaanyaa:
spotted a silver m35 in the riverstone/schofields memorial club car park last night.....possibly the one i always see on annangrove road?
also today spotted a gold arx parked on a road near canterbury road today, around 6 maybe...
now all i need is a bronze and i have the whole set yeh? :nyaanyaa::nyaanyaa:
