that would probably be StageIan...
There is another red one getting around, I have confirmed it's not StageaIan though. The other one has been spotted around Blacktown/Kings Park & Lalor Park.
The one i saw yesterday was pretty distinctive with a SAU sticker, huge roof antennas and a what looked to be a Uruguay sticker too...
The car you saw does sound like StageIan, the other one I have spotted doesn't have any SAU stickers or anything on it.
I was just commenting that there was another one around, up until a week ago I hadn't even seen a C34 in red!! :( Now they are popping up everywhere lol
Spotted Alex(CL11QE) this morning again on annangrove road, wasn't in my 34 though also think i spotted you turning right onto windsor road off pit town road on sat night?
i couldnt see shit this morning with the gay rain......what time saturday night and where abouts is pittown road lol
Yeh same, didnt see you till i was practically past you lol.
Um would of been around 7pm, it is next to Mcgraths hill and is the last turnoff on Windsor road before Windsor if that helps lol
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
