I see bbenny every day. LOL.His car and awesome wheels are my desktop. Drool.
haha nice one Hugh :)
I should have some really good pics of her this week. Went out and did proper shoot with Spoolin12 on the weekend. Including some rig mounted shots of the car with a $10,000 custom carbon camera rig! Cant wait to see how they turn out!
spotted a lady driving a yellow stagea on the southern expressway this morning. i've seen your car at westpac before. are you a regular on here?
btw, is that the Fujitsubo Legalis exhaust?
Edited by pyro-ns
spotted a yellow c34 about 45 minutes ago on Sunnyholt Road near Quakers Hill Parkway, not certain but I think they turned off the parkway heading towards old windsor road.
maybe they were visiting tangents? :laugh: maybe he sold some more of the old front end!
LOL, it seems like the number of Stageas in and around the Blacktown, Parramatta and Hills regions of Sydney is increasing, yet we still very rarely catch sight of each other unless we plan to!
Spotted a red M35 on the roundabout at the Pacific Highway end of Beenleigh Redland Bay Road.
There was a fair bit of damage to the front passenger door....... Expensive!
Gave a wave but it was getting dark so not sure if you saw.... Belong to anyone on here?
saw a yellow S2 In mt druitt westfields carpark bout 4 weeks ago.. got an awkward stare lol... and also was there on tuesday and saw this one (next to mine) anyone here? number plates CML 760 with a kool thing on the dash rather than the clock. lol
I'm pretty sure that's Mike (mike40sydney) - his wife usually drives the car.
Spotted the last few mornings on my way to work in the CBD Melbourne a very sad looking Black m35 plates B4dluk or similar, had a smashed rear window and a f**kload of Brown packing tape all over the tailgate covering the hole, gave me a Major sadface
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
