Spotted a white S2 Stagea with no rear wing on Warrigul Rd last night at 5:15pm approx.
Drove up behind and passed me on the left as I was turning off on to Highbury Rd.
Plate was WQ? - 179 / YQ?-179 I think.
Gave you a toot toot to say hi :)
I should have pulled my finger out and come to the cruise boost the Stag numbers a bit ...but a long day and J.D'n coke got better of me :)
Jetwreck- Thought I saw you round the local area this arvo, pulled over, I slowed right down and was going to have a chat about the tune - but it was that other bloody black ARX thats moved in round us!
It was my brother from another mother...lol. Just around the corner from you bro..anytime you want to drop in drop in.....that way I can size up your bumper for some scoops...oh wait you don't need em....being NA and all :b
Bloody he'll....didn't see another stagea on the road for months now I've seen em everyware!
Anyway spotted another white c34 on jacksons road in warriewood about 5 minutes ago
Edited by Jetwreck
That would be me indeed.. One more night here and back to Sydney. :)
Sweet looking car man.. I got all excited like a little school girl when i saw it lol.. Its rare to see another stagea here, Wanted to say hi but when i came out of jb you were gone
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
