Spotted a white S2 Stagea with no rear wing on Warrigul Rd last night at 5:15pm approx.
Drove up behind and passed me on the left as I was turning off on to Highbury Rd.
Plate was WQ? - 179 / YQ?-179 I think.
Gave you a toot toot to say hi :)
I should have pulled my finger out and come to the cruise boost the Stag numbers a bit ...but a long day and J.D'n coke got better of me :)
Jetwreck- Thought I saw you round the local area this arvo, pulled over, I slowed right down and was going to have a chat about the tune - but it was that other bloody black ARX thats moved in round us!
It was my brother from another mother...lol. Just around the corner from you bro..anytime you want to drop in drop in.....that way I can size up your bumper for some scoops...oh wait you don't need em....being NA and all :b
Bloody he'll....didn't see another stagea on the road for months now I've seen em everyware!
Anyway spotted another white c34 on jacksons road in warriewood about 5 minutes ago
Edited by Jetwreck
That would be me indeed.. One more night here and back to Sydney. :)
Sweet looking car man.. I got all excited like a little school girl when i saw it lol.. Its rare to see another stagea here, Wanted to say hi but when i came out of jb you were gone
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
