[Canberra] Just by chance as I stood up from my desk and looked over the partition out the office window just after lunch today (Monday) I seen a dark green C34 (S1?) going into the open air car park at the Airport.
Edited by QJQ
Quite a few Stageas about yesterday.
Spotted a white M35 in Newtown around 11am.
Spotted a silver C34 and a Silver M35 (gave me a quick toot of the horn) on South dowling st in Surry hills around 445pm.
Spotted a silver M35 in the broadway shopping center car park around 530pm.
Spotted a Volvo 262C Bertone Coupe today on the Nepean Hwy.
Never seen one of those before.
Why would you make a 2 tonne 2 door Volvo.
He so wanted to be a Stagea driver.
They're 1 serious brick! Vince Harmon ( Volvo specialist) has one with a 350 Chev outside his workshop in Mitchell A.C.T. nearly everyday, he's a serious Volvo freak!!!
Silver C34 going through Hartley toward Lithgow on GWH, while a mate & I were having a feed at the Lolly shop cafe; getting ready to ride MTB's back to the top of Mt Victoria.
I think I saw you heading down the mountain while we were on the way up.
Edited by Daleo
spotted 5 stagea's at the JDMST meet at the creek tonight :)
Did you spot mine, Theo? I saw you drive in (or at least I'm pretty sure it was you), so I went for a walk but couldn't find you. :(
Though I saw myself... was on the way to the City, and there was a Silverstone (my colour) 350Rx coming the opposite way out fo the city on the warringah fwy. Lowered and had wheels. Think it was a white on green plate.
spotted a Bayside blue S2 on fullarton rd, travelling towards the cross rd, would have waved but wasnt in the stag as i had just dropped it off
If that was around 440 it would have been me. Spotted twice in one day? No hiding for me.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
