[CANBERRA] While stuck at the lights at Pialligo Ave near the Airport this arvo (about 5:30pm), I caught a glimpse of the distinctive rear of a black M35 which had just turned onto Fairbairn Ave. Traffic was a bit heavier than usual.
Also spotted a few weeks ago a silver C34 at the Glenora Dve / Pialligo Ave traffic lights coming out of the old Fairbairn Air Base. Stared right at the driver but I don't think he noticed.
Spotted a silver s1 C34 at the United servo on Fitzwilliam Road in Toongabbie last night around 9.45pm. It had a set of mesh-style wheels kinda like you'd see being sold at Bob Jane's...
I'd fuelled up there around 4hrs before, and I don't think I've ever seen this car in my area.
Spotted a few this weekend. Yesterday spotted a silver s2 heading home towards launching place, a green/gold series 1 city bound on the eastern freewayin the arvo, and another series 1 just in front of him. Then today a white series 2 in mt evelyn, and a dark green series 1 this arvo heading out of lilydale. Got a wave from the guy in the green/goldie one :)
That was me on the Green/Gold! Its not often you get waves or thumbs from fellow owners these days, was a pleasant surprise :)
(Radelaide)
Dark Blue 35 Stag with Beige Leather (Twin Sunroof Stocky) parked out the front of my house (I think you were maybe at my neighbour's house helping them move in). If youre on here :action-smiley-069:. You couldnt miss the other 2 S2 34 Stags parked at mine.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
