Silver M35 waiting to turn right from Reservoir Rd onto the Great Western Highway in Prospect about 2:15pm, had a dirty big dent in the front driver's side guard between the front wheel and driver's door, and a ladder strapped to the roof.
C34 at Maccas & Shell servo in Northmead, probably around 6:15pm, think it might have been dark green and think you might have seen me parked at maccas while you were leaving.
That was me Dave, I noticed your car as I was driving out to leave, but forgot to post in here about it. Hi! :wavey:
Haha finally! You only live down the road from me and that's the first time I spotted your car, I got pretty excited when i saw it :)
Also spotted a yellow c34 on Abbott rd on Saturday around 10, female driver, had cool looking eyelids and groceries sticker on rear.
Dark blue S1 at Mudgeeraba village yesterday around 1pm, couple of guys on board: I was in the Gloria, heading in the opposite direction around the roundabout: no chance to wave...
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
