  • Replies 93
Hi, I am Christian
Old shitbox R33 - NOZILR
new ROCKET 180sx (soon to be sileighty) - JCKASS
:) :headbang:
i think custom plates are the shiznit - it gives your car an identity.
Originally posted by PranK
Hi, I am Christian
Pranks got his hand on it AGAIN,,,,,,,,,,,.
Your Latest Plate says it all "YOU JCKASS".....
Neil.
guys guys guys..
by by is ok.. ru3l8r, jckass, xcuzme.. there all o... k ..
but there is 1 plate which rulz all other plates.. a master plate forged in the mind of a genius.. a plate which all cars are drawn too...
URMINE ownssss Joooo Allll !!!!!!!
Hi, I am Christian
:D :headbang:
Old Shit box hey, just cause now it is as standard un-modded Skyline (like mine) no need to call it a Shitbox.........
My Line turns heads and its pretty much BOG STANDARD - but the plates are "SKYLYN" !!!!! Best head turning mod I ever bought !!!
Guest Boxhead
thats nothing, i have a pretty much stock na skyline and i turn all those kiddies heads :D:):(
brendanf how long ago did you get those plates? not too long cause i think i remember seeing them available on the rta site.
:shake: :burnout:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
