Quote: "RB30 (japanese Spec) carillo h beam robs,"
There was no RB30 in Japan????? Except the Kaira M30 which was a stroked/bored RB20.
youre absolutely right there was no rb3o in japan BUT the Rb30 skyline 89' model was cast in japan hence (japanese spec)its not a holden block.
  • 1 month later...
  • Replies 50
None of them are Holden blocks.
The "Holden" blocks were all made by Nissan.
(They all have the Nissan emblem cast into them) :D
What bodykit is that on ur car? it looks mad!
wat front bar, side skirts n rear bar is it? n how much did it cost u all up?
Looks like one of those tragic Team JetSpeed kits.
                   387rwkw from an Apexi AX53B70 is pretty good going, considering they rate the turbo at 380ps...
That dyno run was performed at 1.7 bar and the turbo was running out of steam.(started surging).I might be lookin for an rx6 soon!
                   according to my dodgy little chart thing:
 AX53B70 P21 = ~320ps
 Ax53B70 P28 = 650ps and ~690ps
yep i got the p28 ax53b70 , good work.
Then why was it running out of steam?
mine produced 214.8rwkw
my DYNO sheet reads 284.8rwkw  ....
Hi ya guys I t has taken me two years..blah blah blah...
producing a lazy 386.7 rwkw
hahaha
Pick a number and stick to it :D
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
