I Know it's not Skylines but still forced induction OK:
I'm looking into a 4WD , particularly a diesel turbo - And was wondering:
Are diesel turbos subject to the same general rules of modification as petrol turbos ?
ie If you whack a bigger turbo on - do you need to change ECU, injectors etc ??
Are the A/F ration for max performance the same ?
Can you increase boost the stock engines like you can on a petrol turbo ? What is safe ?
How much difference does an intercooler make ?? Same is a petrol ?
Can you increase your exhuast flow (ie bigger exhaust) for more performance ?
What are the gotchas ??
Can you point me to some good diesel turbo web sites ?? Have tried a google search and not much luck ?
Any other tips ??
Cheers,
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/
Hey B-Man
The upgrades you can do to a desiel will give you different power gain too a petrol engine. (Petrol will give you more from intercooler, exhaust, boost etc.) Desil won't make much more power but it will make some.
I'm not sure why it doesnt make as much from the same modifications but might have somthing to do with the way desiel ignites via air compression not spark like fuel :)
Should be same as petrol eg: chiped ecu with more boost and trying to get a/f ratios correct etc.
Jun
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1059966
I'd reckon it would be a bit dodgy - diesels don't rev well past 3000-4000 RPM so their turbos would be designed to make power in this range -
I guess you could use a turbo of an 8.0 litre Diesel on a 2.5 litre petrol engine - but hey - I am not about to go trial and error that sort of shite. :)
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1060291
loool :D
not a hijacking but... i got a silly Q..
could you use Turbos off Diesel cars?? coz i see all kinds of diesel turbos all around for dirt cheap !!
,on a patrol engine that is!!
Diesels have much lower exhaust gas temperature, you don't see 300 degrees celsius. A petrol engine on the other hand will get to tripple that. So if you use a diesel turbo on a petrol engine, the seals last no time, the oil/water cooling is deficient, so the bearings die very quickly, even the turbines and exhaust housings are not designed for the temperature of a petrol engine exhaust.
Bottom line, not a good idea. :)
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1060432
Diesel engines do run much lower exhaust temps, but around 550 degrees celcius is pretty much normal for a turbo diesel engine on full song.
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1060677
Yep 500 degC is the temp in the exhaust manifold, 300 degC is more like the temp at the turbine outlet, which is the more usual measuring point. The difference is the amount of heat (energy) converted to kinetic energy in the turning of the turbine. The result would be similar for a petrol engine, so the comparison is valid.:)
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1060723
I actually meant 550 degrees C at the turbine outlet
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1060807
ive pyroed heaps of diesels and the difference from pre turbo to outlet temps is usually around 100'c, and 550 is pretty normal at the turbine outlet, ive seen them as high as 900, very dangerous then, and people wonder why they crack heads all the time, all the toyota 2LT owners out there will know what im talking about, usually over fuelling massively.
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1061023
Don't Mitsubishi turbo's get used all the time on RB's?
i.e. some of the bigger Trust (MHI) compressors???
Adrian
Chocolate frog for Adrian, T88 is a Canter turbo. But Mitsubishi do upgrade some components like seals, bearings, thrusts, exhaust housing etc to handle the extra heat.:wave:
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1061481
Oi - back OT please :wave:
So if I were to get a 1989 Pajero (2.5L) or Safari aka Cruiser (4.0L)
And I wanted to get some more grunt - what's the best best way to do it ? (keeping the diesel motor)
Can I boost it ? If not why ?
Can I fit a bigger Cooler , Bigger Turbo (T88) he he
Or is this completely not worth it ?
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1061598
My dad has an 80 series turbo diesel landcruiser. In stock trim it doesnt have an intercooler or any form of electronic fuel injection (rotary fuel pump). First thing we did to it was fit a 3 inch exhaust from the turbo back, gave an excellent improvement in power and torque, especially in the lower and middle rev range around the 1700 to 3000 rpm mark, boost rose from about 9 psi to 13 psi. Next was a large frount mount intercooler, power and torque again rose noticeably. We also fitted a air ram snorkel. Its a pipe that runs from the air filter, outside the front guard and up along the A pillar with a scoop on the top to collect cold air from the roof line, has a ram effect when you are driving along, also gave a noticeable improvement. At 4200 rpm in 5th it easil does over 170 km hr, The landcruiser weighs in at 2900kg on the weighbridge. It gets to 170 very easily for a vehicle of its size and is dying for another gear to keep going. Apparently you can lift the boost on these slightly more without to much trouble but need to adjust the fuel pump to deliver more fuel. Also have heard that someone (CAPA?) make a highflow turbo for the cruiser, i am keen to give this a try but funds limit. Towing is also fantastic cruiser=2900kg + boat= 1600kg total weight =4500kg, still gets up and over the 140kmhr
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1061645
An 80 series landcrusier turbo is closer to 2300kg than to 2900kg
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1061666
A STANDARD 80 series is 2300kg yes, Standard 80 series will have one 95ltr fuel tank + an additional 50ltr sub tank, ours still has the 95ltr one but the 50 ltr tank has been replaced with a 170ltr tank for extra range. Total fuel = 265ltrs. Also have steel bull bar with 9000lb warn winch, replacement steel rear bar with spare wheel carrier (needed because the 170ltr tank takes up the space of the spare wheel underneath, hence shift spare wheel onto swing bracket attached to new rear bumper) also have removed third row of seats and replaced with drawer system which is full of tools and recovery gear, and then theres the engel fridge etc, it all starts to add up.
Cooling the air to much for a diesel will result in power loss, Diesels do not have spark plugs to ignite cumbustion, it is done by compression ignition and heat. Diesels will usually run about the 20:1 mark, the high pressure causes the diesel to combust in the cylinder the heat helps this process, thats why diesels are equipped with "glow plugs" to warm them up a bit on cold start. To cold an induction can actually affect the engines ability to combust the diesel fuel totally and hence effect power. (I thinks thats the theory anyway).
https://www.sau.com.au/forums/topic/54075-ot-diesel-turbos/#findComment-1061752
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
