There was supposed to be some getting set up on the M4 west of sydney around May this year for a 1 month trial where ofenders were issued a warning during the first month and then straight into full use.
I can only guess that it never happened because i would definately have received something by now.
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1063338
Nah, he'd probably just be involved in a crash caused by one of the numerous other, almost un-enforced dangers of driving, or by someone who is either too busy watching their speedo to notice traffic, or is of the growing-in-popularity mentality that if they're not speeding, nothing can happen to them.
Isn't Victoria's road toll the highest in years, despite having harsher than ever speed enforcement?
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1063382
those cameras that monitors the time and speed of trucks on the highways.
It will be used on cars soon also.
:chop:
You mean those SAFE-T-CAM things??
i remember one of the first times i did a long trip, i had no idea what they were so i slowed to the speed limit thru each one...realised later they were for trucks :Oops:
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1063617
another dumb idea about making money. imagine if you dont have cruise control... or even with it...high stress freeway driving!
*oh no i am going 125 instead of 110 down this hill, better brake suddenly and cause a 40 car pileup because all the mums in falcons behind me are tailgating*
every time i have driven along the m4 during the day i have been tailgated, never by p platers majority of the time by females in large sedans. scary.
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1063997
yep - those things, but now for cars. I usually stick my fingers up when i drive though just to let them know that im awake.
wouldnt this be an infringment on the privacy laws ?
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1064240
  • 4 weeks later...
The Point to Point speed cameras are already on the M4 in sydney between the cumberland Highway overpass and the bridge that goes over church street. They arent very easy to spot though, on the cumberalnd highway overpass, they are almost tucked up under the advertisement sign on the bridge, as you approach look up, your on camera :). they look like the digital cameras in the bottom pic of the below link. The second set of cameras is on the existing safe-t-cam and variable speed limit sign framework just on the beginning of the bridge over church street. As the site mentions the cameras are only on the eastbound route. Theyve been very tricky about installing these cameras and hiding them, and legally they need not add extra signage drawing attention to them as they use the speed camera warning signs for the cumberland overpass speed cameras to cover their asses (hence only eastbound). They really didnt want anyone knowing what they were up to till its too late, as the website states they will be activated ~june 2005.
http://www.rta.nsw.gov.au/roadsafety/speed...mera_trial.html
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1093784
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
