My AVC-R does a few weird things. Mainly in the overboost department. I have set it to run .65bar however at times it spikes up to .75 or .80 bar before dropping to .65.
a. Is this normal??
b. Have I got it hooked up right. I have a vaccume line comming off the "surge tank" which has a t piece. One line goes to the pressure sensor the other goes to the BOV.
the apexi documentation is kinda crap..
I am assuming the Air Filter Pressure Regulator is the BOV right.
https://www.sau.com.au/forums/topic/54271-avcr-question/
Drop the duty cycle down. When the AVC-R thinks the duty cycle is correct (when its not overboosting) it will change from three numbers (e.g 055) to ***. Then just run it in self learning mode for a while to self tune it a bit and it should all be good.
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1064511
Whats the T piece for ?
Are you running a external wastegate or stock set-up ?
For stock set up it should go from your intercooler pipe/turbo/serge tank or were ever you have it plumbed into. That goes to [NC] on the avc-r solinoid and [COM] goes to turbo actuator.
Check your F/B control if this is too high you will get spikes. And as other's said adjust your duty cycle to get your boost to what its set at.
Jun
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1064931
This looks like a good thread to put my question into.
I've drawn a graph (using ms paint, please forgive me) of my boost curve on the road.
It doesn't do this on a dyno but it does on the road. It's most pronounced in 2nd gear but does still do it in 3rd.
I have the boost duty set quite high because it struggles to get to the set boost. (0.85 bar) It often peaks at 0.78 or so even though I have it set to 0.85.
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1065166
T piece is for splitting the vaccume line off the plennum / surge tank. 1 goes to the AVC-R sensor the other goes to the BOV.
I will sus out this F/V control you speak off. Might also try dropping the duty cycle, however since the boost is level after the spike not sure if thats the cause. Its almost like it delays the opening of the waste gate.
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1065383
a. Is this normal??
In that diagram "Air Filter Pressure Regulator" is acutally 2 things "Air Filter" refers to the small plate shapped thing to the left of the text and it's the air filter that goes in the vacuum line feeding pressure to the pressure sensor (it comes with the kit). "Pressure Regulator" refers to the Fuel Pressure Regulator.
HTH mate :)
Richard
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1065389
What is your start duty set to.
This can able you to spike your boost or under spike it. might help level out your graph a little bit.
It's not ramped at all at the moment. I might try easing it off in the lower revs so that it doesn't hit so hard.
Just feels quicker with a hard hit of boost. :)
Ta.
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1065440
Ahhhhhhhhhhhhhhhhh!
I got you dude.. yeah. those little clear air filter things!!
BING WAHHHHH
might do some reworking of these vaccume lines.. see if it helps the spike issues..
Yep, that's the ones. Man you got gipped though if they are clear, my trust thingy came with green ones :looney: yeeha!
The re-working might help, but it sounds like it's most likely a tuning/programing problem.
Richard
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1065875
hmm, I don't know of any places in melbs but any place that sells all that kind of nice flashy stuff (avcrs etc) would have 'em. I know in sydney I'd go to somewhere like advan, or UAS, but if none of the local shops have them you could mail order from syd, or Japan for that matter.
Richard
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1066940
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
