Well... it was pretty much as i suspected.
Found out the radiator is a larger aftermarket unit...
ECU is a standard R33 GTR ECU...
Sam took me for a drive (Dr_Drift) in it... well... now i know what it can do in the right hands hahaha when we got back i was a little shakey and in need of some new underpants but soon got over it :(
We finally got to put it on the Dyno and had a couple of runs... second one blowing a nice little flame but was restricted by the mixture reader in the exhaust pipe... so... we took it out ;)
and this happened :)
http://www.skylinesaustralia.com/photopost.../414flameon.wmv - right click save as ;) its not the greatest quality but i cant actually get the video off the camera and on to the HDD so it will have to do.
Now down to the numbers :(
The car made 207rwkw on 9PSI :)
472nm torque.
Not bad figures for a stock GTR engine.... in a 1350kg cefiro ;)
https://www.sau.com.au/forums/topic/54320-cef-zlas-been-dynoed/
  • Replies 68
least my 90kw n/a dosen't tend to drop drive shafts :( I meant that car sounds n goes like it had a lot more. I genuinely thought it'd do around 250rwkw, with a very good curve that shows nice responsive tuning.
Hehe pwnd a couple of kids in a silvia around a few bends today in my old man's car, and they were like WTF at the lights. They noticed the Nissan badge and they go "we din know that nissans made powerful sedans..." so I gave them a few Duet-SS aided dori demo's in the family sedan.
lmao
of course it sounds a lot harder it has a 3" drain pipe from the front pipes STRAIGHT to the rear :D
and it can drop driveshafts cause it has the power to do so... unlike someone elses car :P
jetdat - yeah i have to go out to keysborough tomorrow to see a guy from these forums to get some work done so will be stopping by to see if anyone can help me install the part... :)
monkey - all u would need to do is ad more boost to about 12 or 13psi and tune it properly and it should easily be able to run into the mid or lowmid 200s... but u dont need it for dorifto... like u said tho it is a good base to build from.
nice ni sorry I couldnt make it I ahd every intention of being there but other shit jsut took over.
I told yu you need to go for a drive with sam he knows his shit eh :P
congrats on the figures dude . btw my pissy little sr made 221 rwkw & 748 nm of torque not bad for a 4 banger.
still a great figure for a stock motor and as you can see you dont need 300 + rwkw to drift really weel unless your name is sam
cheers
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
