Inasnt did spin. I might have a rb26 but it only has 211rwkw and crap tyres, nearly no brakes on the last lap and kyb street shocks with a blown rear with no other suspension mods so I think 1.31.86 on the last lap is a pretty good time considering geoff managed a 1.31.60. The one under geoff on the time sheet.
Good times mate. I know the feeling with the crap shocks, mine are stock and the RR is shot so the car is somewhat underdamped. Makes it tricky. I felt I would have done a 1:30.xx had I not had to contend with the tools in the TVR and the BMW M3, who I gave 100m onto the main straight and the wanker held the inside line into turn one. Competely wasted the session. Can't wait for the opportunity to get decent coilovers.
  • Replies 138
The attitude of these types of people are, "I have the cash, will do what I like in my new M3 (b/c an M3 makes me an excellent driver), screw you and the fact that you're faster".
Tools :whip:
As a result of these fools I didn't get one flying lap in that last session :D
I expect it is more a case of 100% concentration on getting their car around the track so no idea what is going on behind them. Trust me, this attitude has nothing to do with the car, it is just that those cars were fast enough for it to be a problem for you.
Even F1 drivers have the same problem. But the fact is, if you want clear laps you make them yourself if the other people are not coming to the party. Slow down on the back straight or somewhere that won't affect your laptime and make enough space so that you will not catch up with them. You had three flying laps to sort it out...
It is exactly the same problem you get on the Great Ocean Road etc...
yeah, maybe the case... might have jumped down their throats abit, but it is still a common courtesy to let the faster cars through. At one point the TVR had three cars in tow...
I did end up waiting at the back straight for 1/4 lap to try and clear them, but was too late and didn't get a full flying timed lap :D
Yeah 100% with you on that, they should let the faster cars past.
Though that does mean that they have to wreck their flying laps too.
I used to always try and go out last in the session and wait as long as possible on the warm up lap. Then unless there was a very big speed difference I used to always get a clear run. The problem you had happened too often for me to try any more and there are always trackday n00bs.
No the sessions were based on expected lap times and colour coded, so what were they doing going that slow. It was all I could do not to shove through on the corners but we all agree to be polite and give way. I pulled almost the full length of the front straight on the TVR before Dandenong corner on the first lap and that is just criminal as 2 others were in front of me. I told the guy in the TVR if straight line speed was all he wanted, go annoy a drag strip.
His excuse was we weren't trying hard enough to pass and weren't close enough so he didn't give way. On top of it all the flaggies let him continue his crap.
Not close enough????
I almost tonked him about 5 times through the corners - I was seriously standing on the brakes not to rear end him b/c his braking points were so early!!!
I was actually starting to back off because I was worried that I would get too excited around a corner and collect his slow-arse back end... :Paranoid:
Ok back to the photo's :)
Here are some my friend took with a slr but i had to drop the size down alot to make them a reasonable size
http://www.skylinesaustralia.com/photopost...ll/ppuser/11694
On every session I had to overtake most of the cars in my group like the escort, 260z, mx5, celica and that old jag, but most times i approached them near the straights and they waved me past but still slowed me down a bit through the corner and ontop the straights.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
