Can anyone tell me about the LSD's in an R33 GTS-25T? I have read that the manual cars come standard with an LSD, however after fitting new coilovers recently I've found that if one of the rear wheels lifts up such as when going up a steep driveway the wheel without contact spins endlessly without the LSD ever engaging. Is my LSD worn or how can I tell if I actually have 1???
Cheers
https://www.sau.com.au/forums/topic/54449-lsd-woes/
There MAY be a small tab on the rear of the housing with "LSD oil only" written on it, or something like that.
Alternatively you can jack up the rear end of your car.....spin ONE wheel and if the other wheel spins in the SAME direction it is LSD, if it spins in the OPPOSITE direction it is open diff.
To check the condition of it have a mate hold one wheel while you spin the other, if there is little or no resistance then it is basically stuffed........of there is reasonable resistance you have a decent lsd.
Hope that helps
https://www.sau.com.au/forums/topic/54449-lsd-woes/#findComment-1073313
Viscous LSD's don't immediately lock when one wheel is spinning, they come on gradually as the viscous fluid heats up. You can only really test their action after you have been driving (and using the limited slip) for a while. ie; don't walk out in the morning jack the car up and expect to get a satisfactory result.:P
https://www.sau.com.au/forums/topic/54449-lsd-woes/#findComment-1073521
i think its time you invested into 2way or 1.5way lsd, its diffinately worth while!
We ran one of ours as a BOC locker on the weekend, while we wait for a proper one to arrive from Nippon.
Worked a treat...
There are only 3 types of viscos LSD, 1. New ones, 2. Ones that don't work, 3. Welded ones.
Should be able to score yourself one for round $700 S/H
TT
https://www.sau.com.au/forums/topic/54449-lsd-woes/#findComment-1077740
Jase, when i had my factory viscous lsd and super hard tein coilovers, id also spin one wheel real easy while going slowly through driveways. In my case the suspension was so stiff that when going through a driveway angle one of the rear wheels just lifts off the ground, allowing it to spin, and i would never feel an "lsd effect" in these conditions. Launching however my lsd would work fine. Do a burnout, and id have two nice black lines.
As mentioned its easy to test, after a good drive give it some boot off the line and check your tire marks on the road.
https://www.sau.com.au/forums/topic/54449-lsd-woes/#findComment-1077908
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
