You are so evil  :chairshot  :cheers:
:jk: i reckon with all that power and talk you would have to get use to it and im sure your not going to crash...............i thought cassi was the veil one
anyway i really need some sleep, nice to meet you allas this is the first time i have posted exept for the for sale items, its been fun, keep those posts going, the crown is ours:smile:
yeah Cassi is the most evil person i know (she scares me :cheers: lol) Yeha ive already been driving it for a year so i got the hang of it now.
Mad lahdaz man :cheers:
Lets us know when ur in town :)
Whats changed?
I need to pay rego soon :cheers:
There goes $670...wasted
Am not really sure wats changed. Ill check it out when it comes out.
Damn you guyz pay like $100 more for rego than down here.
Langwarren, i think that's the spelling...it's been too long...
All my family is there. Grandma in Chelsea, Grandad in Dandenong, and other people other places i forget.
I haven't been to the ol' Victoria in like 6 years.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
