Ooooh, so i'll be able to hear you coming now Leigh? Not just sneak past with el' silento stock exhaust
hehe come on when i hit it hard it makes a little bit of noise :D but yea i am acutally a bit worried as to how loud it will be :) i dont want to be getting defected left right and centre
3" dump/front pipe
high flow cat
HKS super dragger exhaust not sure what size the muffler is maybe 4.5 its pretty frickin big though lol
Most people are on tech support :P Telstra tech support sux :( (u can guess who that it directed at)
Telstra's tech support may not be the best, but Bigpond's is pretty damn good for having over 600,000 Broadband customers
so what... since there is nothing gion on in VIC whoring takes place here??
Maybe i can stike up an intelligent conversation here as its seems that VIC's combined IQ is inversely proportional to the number of posts there... robs whoring has dumbified a city
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
