It seems like a great idea when you leave to go out..."Nah...clubs are hot, i won't need a jacket" then you leave and "p0w! frozen!"
I know!! The time I went out i was dancing all night, went to shooters, quatros, inblue D:, moose and then echo so i was like hot until i was waiting in the stupid taxi rank!! BAH!
